Author Topic: info needed??  (Read 553 times)
Offline 70383RT
  • Newbie
info needed??
« on: April 04, 2011 - 07:43:59 AM »
i am currently looking at a 1970 dodge challenger RT 383 4V 335hp 4 speed with these options. everything seems to be matching up. the number on the block near distributor is F 383104321HP but doesn't decode to a date? so whats numbers should it have?? the owner is saying it is a completely matching numbers car. any help and info would be greatly appreciated.
VIN No is JS23NOE119229
N42- BRIGHT EXHAUST TIPS
N85- TACHOMETER
R22- AM 8 TRACK
V1X- VINYL ROOF (BLACK)
V68- STRIPE DELETE CAR
A62- RALLEY DASH
C55- BUCKET SEATS (VINYL)
J25- 3 SPEED WINDSHIELD WIPERS
M21- DRIP RAIL MOLDINGS
N41- DUAL EXHAUST
EB5- BLUE FIRE METALLIC PAINT
B12- H.D. DRUM FRONT BRAKES
E63- 383 4V H.P. V8 ENGINE
D21- 4 SPEED TRANSMISSION
Also equipped with power steering & more.
Offline 'Cuda Hunter
  • Tastes Like Chicken
Re: info needed??
« Reply #1 on: April 04, 2011 - 08:38:54 AM »
You need to look on the oil pan rail on the passengers side.  There will be a flat boss that will have your vin numbers stamped into it.
Re: info needed??
« Reply #2 on: April 04, 2011 - 08:40:29 AM »
Also, check the cowl for your vin number stamp.  Usually by the plastic grate where air goes into the cowl.
 As well as the radiator support.  Usually on the engine bay side of the radiator support.
