Author Topic: What temp T-stat should I use?  (Read 837 times)
Offline Barracudadan
« on: April 04, 2011 - 10:10:34 AM »
I need to put in a T-stat there was none in the motor just not sure what would be the best temperature stat to use. I was thinking maybe 180*. I have a stock 318 no A/Cwith a 4 blade fan bolted directly to the water pump.Thanks!
Re: What temp T-stat should I use?
« Reply #1 on: April 04, 2011 - 11:00:40 AM »
Yes, I would go with the 180* T-stat.
« Reply #2 on: April 04, 2011 - 11:06:27 AM »
Thanks Mek I`ll do that.
Offline femtnmax
« Reply #3 on: April 04, 2011 - 10:21:04 PM »
Many Tstats now come with a small bleed hole in the flat flange of the Tstat; purpose is to help remove air as cooling system is being filled.  Works real well.
Any Tstat I buy now, if it doesn't have a bleed hole, I drill a 1/16 hole or a little smaller, then deburr the hole edges. Take a little time filling the cooling system and there is usually very little air trapped in the system.  :2cents:
Phil
« Reply #4 on: April 07, 2011 - 02:05:52 AM »
I agree with the 180 T stat hot enough but not too hot
« Reply #5 on: April 07, 2011 - 07:28:15 AM »
 :iagree:  I do the same thing on all my cars.
Offline mopar12372
    • mopartech
« Reply #6 on: April 07, 2011 - 10:53:33 PM »
180-190 imop
RESTO PICTURES
