Author Topic: Park lights???  (Read 1588 times)
Offline afrochallenger
Park lights???
« on: December 10, 2004 - 04:09:26 AM »
Just need to know how the front parl lights are supposed to be wired up on my 71 chally. I am assuming that it is the turn signal lights that come on and not the head lights when the headlight switch is moved to the first click. Only my tail lights light up at the moment.
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
Re: Park lights???
« Reply #1 on: December 10, 2004 - 10:29:00 AM »
THE FRONT PARKING LIGHTS ARE ALSO YOUR TURN SIGNALS- DOUBLE FILMENT BULB.
check at the bulk head connector to make sure the wires go there.
then make sure the bulbs are ok!!!
Re: Park lights???
« Reply #2 on: December 10, 2004 - 10:48:03 AM »
the front park lights should be the same as the tailights & work with the lights switch in the first or second position
lemonboy69
Re: Park lights???
« Reply #3 on: December 11, 2004 - 01:02:55 AM »
Are these case ground or physical ground?? :dontknow: Found out the hard way on my '69 'Cuda that the parking lights are case ground...
LB
Re: Park lights???
« Reply #4 on: December 11, 2004 - 04:29:44 AM »
They're case ground. :madvibe:
Re: Park lights???
« Reply #5 on: December 20, 2004 - 01:37:58 AM »
Thanks guys - the wires are there - bulbs are good - I think it's a bad contact at the bulk head connnector.   :dontknow:
Re: Park lights???
« Reply #6 on: December 20, 2004 - 01:48:10 AM »
Use a voltmeter & check for power
