Misc Mopar/race parts for sale-Mich
Author Topic: Misc Mopar/race parts for sale-Mich  (Read 854 times)
Offline 6PKRTSE
« on: April 07, 2011 - 08:11:44 AM »
Engine:
1-used Blown 426 Hemi blower cam $ 100.00
1-used set 452 b.b iron heads $100.00
1-new 3.750 Eagle 8 bolt flange HEMI forged steel crank $500.00
1-used set of b.b. main cap & bolts $40.00
1-new P3690936 cam offset bushing kit $20.00
2-new P4876926 HEMI spark plugs (4 plugs per pack) $15.00 ea.
1-new Hemi/b.b. many cam & plug dowel pin kits all mixed together $40.00
15-new P4006767 b.b. / Hemi lifters   $5.00 ea.  $60.00 for all
1-new PD-17 Durabond b.b cam bearing kit $ 20.00
1-new P4529699 sfi approved b.b./hemi damper $250.00
1-used lot of misc cast iron exhaust manifolds, intakes, oil pans, alternators, starters etc.
1-used 70’ 440 iron 4 bbl intake- $40.00
1-used 70 4 bbl carb linkage & kick down $30.00-TRADED
1-used 70 440 power steering pump $40.00-TRADED
1-used 70 iron water pump housing $40.00-TRADED
2-used 70 440 upper & lower motor mounts $ 50.00 per pair-TRADED
1-used d.s. lower motor mount bracket $20.00-TRADED
1-used set of 4 groove water pump pulleys $ 40.00/set
1-used 440 oil pump $10.00
1-new set Speed Pro p/n R9771+5, 4” bore 1/16 1/16 3/16 ring set $40.00
1-new set Total Seal 4.310 bore 3.0MM scraper & expander set $ 45.00
1-used 440 valley tray $10.00
2-used sets of std 440 pistons w/ rings & pins $100.00/set
1-used set of 440 LY rods $100.00/set
2-used 440 distributor w/ vac adv. $10.00-TRADED
Ram:
1-new 94-02 club cab body moulding $10.00
1-used 94-02 tail gate handle & hardware, everything but tail gate shell $40.00
1-used 94-02 front license plate bracket $25.00
1-used 94-02 day/night rear view mirror $25.00
1-used 76-93 B.B. truck trans cross member-SOLD
B-Body:
4-used Bullit style 68 Dodge hubcaps $25.00 ea.
1-used B-Body transmission cross member $40.00-SOLD
1-used chrome master cylinder cover $10.00
1-new pair of lift off hood brackets $60.00
E-Body:
1-used E-Body power Steering gear box $100.00-SOLD
1-used E-body 727, 8-3/4 driveshaft $100.00
1-used E Body trans cross member $50.00
1-used E Body heater core assy $150.00
2-used E Body rear leaf spring brackets $40.00
A-Body:
1-Used A body transmission trans cross member-$40.00-SOLD
Drivetrain:
1-used 4.0L Jeep auto trans yoke $ 40.00
1-used 727 trans yoke $ 40.00
Call 1-313-505-7948 Make an offer on all items. I have no use for any of the items & need to make room.
« Last Edit: April 11, 2011 - 12:17:07 PM by 6PKRTSE »
1970 Charger R/T S.E. 440 Six Pack
1970 CHALLENGER R/T, 25.5 Cert, 528 Alum 16 plug HEMI twin turbo.
1970 Charger 500 S.E. 440 4 BBL.
1970 Road Runner 383 4 BBL
1996 2500 RAM 488 V-10 4X4
2012 Challenger R/T Classic
Offline ksierens
    • 70 Challenger Resurrection
Re: Misc Mopar/race parts for sale-Mich
« Reply #1 on: April 07, 2011 - 08:23:22 AM »
Do you have the part numbers off the exhaust manifolds?
Kurt - SE Michigan
Offline 572b1cuda
« Reply #2 on: April 07, 2011 - 11:31:11 AM »
pm sent for 440 distributors.
Offline 6PKRTSE
« Reply #3 on: April 11, 2011 - 12:13:30 PM »
Sorry guys just traded off the manifolds & the distributors.
Offline sac2dude
« Reply #4 on: April 12, 2011 - 05:51:43 PM »
I could really, REALLY use that E-body driveshaft!  Does it come with the slip yoke?  Is it a 7290?   I need both - I'm in the middle of swapping from a slant six, 904, etc..  to a 440, 727, 8 3/4.
Of course, your in Michigan and I'm in California...  :-(   Anybody know how to ship a driveshaft?
