Author Topic: Widest rim I can use after moving rear leafsprings in  (Read 1921 times)
Offline challngd73
« on: April 07, 2011 - 07:07:34 PM »
I was going to use the rear leaf spring relocation brackets and was wondering what the widest rim I can use after I do that without any other mods.  thank you
Offline Katfish
  • 70 Challenger
Re: Widest rim I can use after moving rear leafsprings in
« Reply #1 on: April 07, 2011 - 07:19:38 PM »
You could easily fit 10" rims with the relocation kit.
Here's my set-up
Rims are American Racing Torq-Thrust
ARE-105MS7865B
ARE-105MS8965B
Dr Diff 1" relocation kit gives me about 0.75-1" clearance from tire to leaf spring and rim to quarter panel on each side.
17x8 (4.5" BS) up frt - 17/225/50 (25.9") $95 each
18x9 (6" BS) in rear - 18/275/40 (26.7") $115 each
I looked at the 285's for the rear but it was almost $100 more per tire. I looked for common sizes to keep the cost down.
Offline aris_unlimited
  • Project in full swing
« Reply #2 on: April 08, 2011 - 03:34:47 AM »
Can't believe I never thought of a leaf spring relocation kit to make it easier to tuck wider tires I wanted under the car. Does relocating the leaf springs alter the ride at all? Alter the handling?
Cuda is gone :(
74 satellite, daily driver/project now
Offline challngd73
« Reply #3 on: April 08, 2011 - 05:35:22 AM »
Thanks a lot, that's all I was looking for was to be able to tuck a ten inch rim back there!
« Reply #4 on: April 08, 2011 - 11:22:47 AM »
Yes, but not significantly. I did the calculations once and I think the 1" kit alters wheel rate something like 10-12# and the 3" kit changes it around 25-30 #, in other words, not enough for most people to notice the change.
I did the 1" kit on my Challenger and I've got a 10" wheel with a 12" tire and still have plenty of room.
Offline challngd73
« Reply #5 on: April 08, 2011 - 12:35:09 PM »
Now here is a question, typically, how much does it run to widen a rim, and where would i go to do something like that?
« Reply #6 on: April 08, 2011 - 03:59:42 PM »
You can't widen a rim. A stock set-up will take an 8" wide rim in the rear if it has the correct backspacing. To move up to 10" rims, you will need to move the leaf springs in some.
Offline challngd73
« Reply #7 on: April 08, 2011 - 04:45:05 PM »
Ive seen a number of people have rims widened on my other car forums..
« Reply #8 on: April 08, 2011 - 06:53:16 PM »
Depends on the rim. Some can be, some can't.
Offline mopar12372
    • mopartech
« Reply #9 on: April 08, 2011 - 07:47:49 PM »
15x10x12.5 is what i fit in the 1973 barracuda after moveing springs in.
RESTO PICTURES
Offline burnoutking-1
« Reply #10 on: January 08, 2012 - 06:35:32 PM »
Not sure why you can't fit 10" rims back there?  I am running 275/60's on a 10" rim. Not much room left, but they fit...no rubbing.
