When I put the superstock springs in I also went with the mopar performance adj pinion snubber. I had it adjusted to where it didn't hit the floor pan when going over bumps, which worked out to be about an 1 1/2 to 2" from the pan. I bent this snubber on a 2nd gear shift to where it rubbed the pinion yoke, took it off and fixed it and it happend again. Then I bought another snubber, I can't remember the make right now but it's the heavy duty threaded screw in adjustible type. Had it set the about same an 1 1/2 to 2" from the pan, didn't bend the snubber this time, bent the pan instead. Guess I'm gonna have to take it alittle easier on my 2nd gear shifts! I have the car apart now doing a repaint and am installing weld in frame conectors. I think when I straighten the floor pan I will try to improve on the factory bracing in that area.
Thanks for the replies
Jim
