Author Topic: Removing E body gas tank  (Read 8714 times)
Offline DocMel
« on: April 10, 2011 - 01:15:14 PM »
Seems pretty much straight foward.  I need to remove the gas tank in my 71 Cuda.  Some questions though.  I have a haynes, but its pretty much worthless as far a E body specific diagrams
1.  I cant access the nuts that hold the gas tank straps.  The gap between the rear of the gas tank and body are a pretty tight fit.  I had thought maybe access from above thru a truck floor plug, but none come close to the area I need access to:  Any hints to gettting these nuts off?
2.  Filler neck:  Looks like there are 2 places I need to remove the filler neck mounts.  At the gas cap area and at the truck floor.  Correct?
Any advice is appreciated, Thanks
Offline 67vertman
  • Member since 9-23-2005
Re: Removing E body gas tank
« Reply #1 on: April 10, 2011 - 01:26:20 PM »
Mel. you should remove the bumper and drop the rear valance, it makes it easier to access the bolts and the tank will drop right down.
As to the filler neck.....you are correct!  remember to lube the gasket to the tank when you put the filler neck back in.
Offline HemiOrange70
« Reply #2 on: April 10, 2011 - 03:41:37 PM »
Stickin' that neck into the tank requires alot of pushin'
Offline dutch
« Reply #3 on: April 10, 2011 - 04:51:49 PM »
 :iagree:   I even think you won`t be able to get the straps in or out with the valance in place, if you got the nuts off...
*** Bart ***
Offline DocMel
« Reply #4 on: April 11, 2011 - 02:47:49 PM »
 I didnt even think to remove the valance and bumper ::)  Sounds like a plan,  Thanks
Offline daveh
« Reply #5 on: April 11, 2011 - 03:03:38 PM »
What's good to lube it with?  Now watch the jokes I was being serious.
Offline 500Stroker
« Reply #6 on: April 11, 2011 - 04:54:34 PM »
All I had to remove was the valance on mine.  Bumper was not in the way.
Offline tommyg29
« Reply #7 on: April 11, 2011 - 08:36:01 PM »
I took my valance off, but also had to remove the tailpipe tips (fortunately they are just clamped on) to get the valance off. Depending on how tight the fit is, you may have to take the bumper off first but I had enough room under the bumper to remove the valance bolts.
Offline DocMel
« Reply #8 on: April 12, 2011 - 04:53:48 PM »
Remoning valance was good enough:  Thanks to all
Offline 67vertman
« Reply #9 on: April 12, 2011 - 05:11:11 PM »
 :smilielol:  :smilielol:
I have used Vaseline.  If it gets into the fuel tank it dissolves.  :2thumbs:
Offline 500Stroker
« Reply #10 on: April 12, 2011 - 06:17:01 PM »
Get the gasket warm and soft by leaving it sit in the sun a while.  I used WD-40 after using sandpaper and brake clean on the filler tube
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #11 on: April 12, 2011 - 08:42:22 PM »
I used a bunch of WD-40 on the filler neck.  I had a lot of trouble pulling mine out.  If you do, stop and reposition the filler neck.  The right angle really helped out.
On my Challenger, I didn't take off the rear valance or bumper to get to the J bolts.  I just used a deep socket and angle attachment.  :2cents:
Offline 74challenger03
« Reply #12 on: March 17, 2016 - 08:45:03 PM »
do you need to unbolt the filler neck to pull the tank? Sender went bad.
Offline JH27N0B
« Reply #13 on: March 17, 2016 - 10:10:26 PM »
You have to remove the screws attaching the filler neck to the 1/4 panel. And the screws attaching the filler neck gasket to the trunk floor.  And then you remove the tank and filler neck as an assembly.
Offline Katfish
  • 70 Challenger
« Reply #14 on: March 17, 2016 - 10:52:03 PM »
No need to pull tank to replace just the sender.
I've done mine in the car several times.
