Author Topic: Removing E body gas tank  (Read 8713 times)
Offline loco340cuda
Re: Removing E body gas tank
« Reply #15 on: March 17, 2016 - 10:57:10 PM »
Mel. you should remove the bumper and drop the rear valance, it makes it easier to access the bolts and the tank will drop right down.
As to the filler neck.....you are correct!  remember to lube the gasket to the tank when you put the filler neck back in.
What do you lube the gasket with?
1970 Cuda 340 4-speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
