Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
no spark help
« previous
next »
Print
Pages:
1
2
3
Author
Topic: no spark help (Read 2943 times)
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Re: no spark help
Reply #15 on:
April 18, 2011 - 02:55:53 PM »
ECU= Electronic Control Module, The module receives a signal from a magnetic pickup or in the distributor. The module uses this signal to open and close the ground circuit to the ignition coil to fire the spark plugs.
If it's Bad or Not getting enough power No Spark.
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
Jocigar
Jr. Member
Re: no spark help
Reply #16 on:
April 18, 2011 - 04:33:22 PM »
thanks, it sounds safe to say that the coil output should not have a constant 12v as it did. maybe ecu issue then.
Logged
UKcuda
Full Member
Tell them I'm on my way
Re: no spark help
Reply #17 on:
April 18, 2011 - 06:22:32 PM »
Has he got an ECU - it's a 1970 car ?
Logged
'72 'cuda
Bullitt-
Permanent Resident
Re: no spark help
Reply #18 on:
April 18, 2011 - 06:42:42 PM »
Quote from: UKcuda on April 18, 2011 - 06:22:32 PM
Guess I'm being presumptuous, most folks seem to but It's possible it's a points distributor.
Logged
Huntsville, AL
UKcuda
Full Member
Re: no spark help
Reply #19 on:
April 18, 2011 - 06:51:29 PM »
I know what you mean but I just thought, if it's points then maybe we should be checking other variables.
Logged
'72 'cuda
Jocigar
Jr. Member
Re: no spark help
Reply #20 on:
April 19, 2011 - 09:59:29 AM »
I must be wrong but I thought I had both, I can say that the distributer has points that open and close as the distributer shaft rotates.
I also thought I had an ecu mounted on the back of the fire wall. Its a bat-wing shaped unit 4"x4" with three wire plug at the base.
sorry for all the trouble, I should post a picture. It's been a long time since I played with these cars.
Logged
mojavered
Full Member
Someday!
Re: no spark help
Reply #21 on:
April 19, 2011 - 10:01:50 AM »
A couple pics might make a difference?
Logged
Jason
UKcuda
Full Member
Re: no spark help
Reply #22 on:
April 19, 2011 - 10:20:44 AM »
You can trigger an ECU with points, but that doesn't sound like an ECU that you have there as it's not enough wires.
"bat-wing shaped"
Logged
'72 'cuda
MEK-Dangerfield
C-C.com Expert
I don't get NO respect! Member since 1/25/2002
Re: no spark help
Reply #23 on:
April 19, 2011 - 11:32:27 AM »
That's your voltage regulator. The ECU looks similar.
Logged
2016 SXT+. 1 of 524 SXT+'s in Plumb-crazy for 2016.
Jocigar
Jr. Member
Re: no spark help
Reply #24 on:
April 19, 2011 - 01:55:10 PM »
Yes I'm sorry, the "bat-wing thing" is a voltage regulator
I looked up the image.
So it has nothing to do with the no spark issue, correct? I ordered cap and rotor, unlikely to be the problem but can't hurt.
THanks all
Logged
Cuda54
Jr. Member
Re: no spark help
Reply #25 on:
April 19, 2011 - 03:23:42 PM »
Get a new set of points too. If they are not good you will not get spark. Make sure the key is turned to run when you try to get spark. My AAR Cuda had two sets of points.
Logged
Jocigar
Jr. Member
Re: no spark help
Reply #26 on:
April 27, 2011 - 11:12:45 AM »
hi guys I'm back. help me with this... I have a single points distr.
THere are two wires that appear to both be (tied together?) and are going to the spring loaded side of the points.
Here is what I get... holding the center wire from the coil near ground... if I open and close the points nothing happens, but when short the spring loaded side to the screw that holds down the points I get a huge spark every time. I discovered this by mistake, I cleaned the surface of the points and still nothing when they touch... which I would think is the same thing as shorting the spring loaded side to ground?
Am I missing something? wiring is wrong? if the points are bad I find it hard to believe they would not short out to some degree as intended.
THanks... sorry for the long thread.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: no spark help
Reply #27 on:
April 27, 2011 - 11:27:27 AM »
if the condenser is shorted internally , it is the round can with the second wire to the points , it will ground the circuit & fail to make spark , try disconnecting the condenser .
if you have the $ to convert to electronic I would do that
Logged
UKcuda
Full Member
Re: no spark help
Reply #28 on:
April 27, 2011 - 11:45:04 AM »
Sounds like your points are not making proper contact. You probably need to clean the contact surfaces with a very "hard" abraisive like black carborundum paper or something. It doesn't have to be coarse grit, it can be a fine grit, it just has to be hard or it doesn't cut properly into the tough coating that builds up there.
Logged
'72 'cuda
72rtchallenger
Sr. Member
72 to 70 clone
Re: no spark help
Reply #29 on:
April 27, 2011 - 07:20:03 PM »
you might want to regap the points if you havent already tried
Logged
72rtchallenger
my challengers restro at
http://www.cardomain.com/ride/399010
what happens in the garage
stays in the garage
Print
Pages:
1
2
3
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
no spark help
