Author Topic: BLASTING MEDIA!!!!!!!!!!  (Read 1304 times)
Offline chuck
« on: April 17, 2011 - 10:48:30 AM »
I HAVE A QUESTION WHAT MEDIA IS THE BEST AND CHEAPEST TO BLAST THE WHOLE CAR I HEAR SODA IS NOT THAT GOOD FOR THE PAINT IF YOU DONT WASH IT OFF GOOD I HEAR BLACK BEAUTY IS GOOD AND I HEAR STARBLAST IS GREAT I HAVE TO TAKE SOME SURFACE RUST OFF PLUS PAINT WITH OUT WARPING ANY THING  :feedback: :faint:
Re: BLASTING MEDIA!!!!!!!!!!
« Reply #1 on: April 17, 2011 - 11:12:57 AM »
Plastic media is the safest without warping. However if you know what you're doing you can go with a more aggresive media that cuts faster. I did my underside with aluminum oxide.
BTW, chuck. Please turn off your caps lock. It's impolite to post on forums in caps.  :thumbsup:
Offline chuck
« Reply #2 on: April 17, 2011 - 12:03:04 PM »
ok thanks for the info sorry about the caps i use them because i can see them better lol!!!
« Reply #3 on: April 17, 2011 - 12:19:26 PM »
Using sand is not recommended if you DIY. You need a sealed mask with an external air system hooked to the mask. When sand is blasted, it creates Silica dust. If you breathe in silica dust, you can get Silicosis. 3M dust masks will not prevent breathing it. My first blasting, I used sand and my chest hurt for 2 days. Black magic is coal dust. Another bad one needing you should have special mask for.
Read this post. I recommend stripping the outside by hand unless your car is very rusty.
http://www.cuda-challenger.com/cc/index.php?topic=72805.25
Offline cudarag
« Reply #4 on: April 17, 2011 - 05:10:02 PM »
I had my cuda done with walnut shells. Absolutely the best way to go as there is no caustic residue left as with soda. There is done damage or warping  done as with sand .
« Reply #5 on: April 17, 2011 - 05:44:06 PM »
Any pics of your project chuck?
Is it rusty on the outside?
If it's not, I still recommend stripping the outside by hand.
It takes longer but media hidden everywhere is a real PITA to get out of the car afterwards. The heavier the media is per lb the harder it is to get out.
More than one resto shop I have spoken with agrees with me on this. The car has gotta be pretty rusty throughout to warrant a complete blasting inside and out. Then Picklex it after.
Offline TROUBLE987
« Reply #6 on: April 17, 2011 - 08:34:37 PM »
im going to hand strip the body panels and sand blast under hood,floor pans,trunk,under the car
Offline BLA449
« Reply #7 on: April 17, 2011 - 11:04:26 PM »
Dupont Starblast is what we use at our shop. It works really well.
« Reply #8 on: April 17, 2011 - 11:16:34 PM »
The one area most of all to avoid blasting is inside the trunk with the quarters still on.
With them off, you can still do a decent clean out. I had alot of media get into the frame rails even with plugs in the holes. After doing the underside, blow out the inner frame rails as best you can.
Offline chuck
« Reply #9 on: April 17, 2011 - 11:36:24 PM »
the car is in great shape not that rusty at all a littlt surface rust on the floor i want to put lizard skin on the floor and i want to blast  the bottom of the car  so i thaught i would do the whole car i tried to put pic on here but it said pics are to big can some one tell me how to get them on  here i am not computer smart
Offline chuck
« Reply #10 on: April 18, 2011 - 10:57:35 PM »
here are a few pics hope they work
« Reply #11 on: April 18, 2011 - 11:31:12 PM »
Wow nice project Chuck. I would say by the looks of it you could sand it on the outside.
When I did my interior, I sanded it as best I could then sprayed Rust Bullet. Trunk floors were replaced.
I'm not trying to have my car survive for another 200 years. It wasn't very rusty like yours either.
Offline chuck
« Reply #12 on: April 18, 2011 - 11:43:43 PM »
now the hard work begins
Offline chuck
« Reply #13 on: April 22, 2011 - 06:06:03 PM »
 :jumping: i ordered the twins today iwata supernova ls400 base gun 1.4 and ls400 clear gun 1.3 hope they work out anybody use these guns  :feedback:i hope its a good up grade from my old sharpe
