Author Topic: best way to strip paint off stainless?  (Read 11793 times)
Offline 572b1cuda
« on: April 17, 2011 - 12:23:56 PM »
whats the best way (easiest way)to strip paint off of stainless moldings? i took off all the stainless molding off of the 71 grill to repaint the grill and there is paint on every molding :pullinghair:
Offline IMNCARN82
  • LeDZeP
Re: best way to strip paint off stainless?
« Reply #1 on: April 17, 2011 - 03:08:02 PM »
I like 3M Trizact. 3000 grit and polish. Big bucks though... :money: Only sold in a box. You could go 2000.
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline drewcrane
« Reply #2 on: April 17, 2011 - 11:34:16 PM »
I know this sounds crazy but brake fluid,do a test area ,but I have done it ,or use some lacquer thinner  :2cents:
Offline elitecustombody
  • Supra collector
« Reply #3 on: April 18, 2011 - 10:50:00 AM »
Aircraft paint stripper or any paint stripper,hose the parts down with stripper, put them in trash bag or cover them with it for about 15 minutes, rinse off,repeat if there are stubborn areas, but usually that does the trick, it will not harm the chrome or stainless.
Stefan B
Offline moparclown
« Reply #4 on: April 18, 2011 - 09:13:48 PM »
Brian
get some laquer thinner from the hardware store,they usually have small containers of it.And to put a nice finish on it use Mothers aluminum polish on 0000 steel wool(also at the hardware store) and wipe off with a nice soft cloth.
Doug
ps  I wouldn't use brake fluid as it stays in the steel and may show up later and could attack the plastic :2cents:
Offline Jimmy
  • THE Challenge(r)
« Reply #5 on: May 12, 2011 - 05:13:24 PM »
I don't know if it works on automotive paint, but I use a product from Home Depot called Citri-Strip to remove paint. Smells good too!
1973 Challenger w/440
1967 Camaro RS w/502
1967 Mustang w/302
1965 Ford F100 w/429
Offline 72cudamaan
« Reply #6 on: May 12, 2011 - 05:59:36 PM »
Well, I just got done trying Citri Strip earlier today. Shoulda named it citri rip off. I put it on one of my doors, let it set (wet) for 48 hours.
Didn't do a thing to the paint.  :dunno:
If I cant fix it, it's broke
Andy  (phukker whither)
Offline Jimmy
  • THE Challenge(r)
« Reply #7 on: May 12, 2011 - 06:04:01 PM »
Guess it doesn't work on automotive paint then. Works wonders on other types of paint, I use it all the time to remove paint from the porcelain gas station signs I purchase and the paint just slides right off. Oh well, it was a thought.
1967 Mustang w/302
Offline 572b1cuda
« Reply #8 on: May 12, 2011 - 09:01:59 PM »
thanks for the input. i wound up using carb cleaner and 0000 steel wool and they came out real nice. i had to strip the upper and lower long moldings and all 6 cheese grater moldings. my fingers hurt a little when i was done but it was worth it. and now i get to put it all back together! :cheers:
Offline AARuFAST
  • AARuFAST
« Reply #9 on: May 13, 2011 - 11:27:36 PM »
My experiance.
No No if u leave the stripper on to long
 it will curl dry out and harden the paint.
Read directions.  Paint should curl in 15 minutes.
I dip the steel wool into stripper to activate the process.
Steel wool will ruin chrome and scratch stainless steel.
I polish my stainless with a bench polisher. variable speed 1500 to 2300 rpm .
Get some stainless buffing compound and buffers and Mechanix gloves. get er done.
Google stainless polishing.
« Last Edit: May 13, 2011 - 11:49:54 PM by AARuFAST »
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
