Author Topic: Engine Ticking  (Read 1000 times)
Offline Fleet 500
Engine Ticking
« on: April 20, 2011 - 04:48:26 AM »
Most people know about how the engine "ticks" after it's turned off after being driven. Well, I noticed that the engine in my '66 Plymouth Fury (383-4 bbl) makes a ticking sound once it's warmed up and still running. A distinct ticking sound which I've traced to the area at or near the manifold heat control valve.
Has anyone here noticed that with their car(s)? The tick, when the engine is running, happens about once every 10 seconds and can be heard inside the car when it's idling.
Offline 72cudamaan
Re: Engine Ticking
« Reply #1 on: April 20, 2011 - 09:39:37 AM »
Exhaust leak.  I use  a length of 3/8" brake line as a stethescope to locate exactly where it is coming from.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline DocMel
Re: Engine Ticking
« Reply #2 on: April 20, 2011 - 12:25:59 PM »
The older valve trains are notorious for getting loose:  By loose, I mean check the nuts that hold down the rockers and rocker arm assemblies
Just remove the valve covers and check the tourque on those nuts
Exh leak like mentioned could def be the culprit
Offline Fleet 500
Re: Engine Ticking
« Reply #3 on: April 20, 2011 - 08:04:43 PM »
Yeah, it does seem like an exhaust leak.
I don't think it's the valve train because it doesn't increase in frequency when the engine is at higher rpms.
Offline mopar12372
    • mopartech
Re: Engine Ticking
« Reply #4 on: April 21, 2011 - 10:28:10 PM »
does the engine have oil in it?
RESTO PICTURES
Offline Fleet 500
Re: Engine Ticking
« Reply #5 on: April 24, 2011 - 04:58:42 AM »
It does. I check the oil often because it does burn it (original, non-rebuilt engine).
Last I checked, it was at or slightly below the "full" line.
