News:
Trampoline springs My neighbors have a trampoline in there back yard,Will wait until night to borrow a set, AARuFAST
On my hood it is a repop, where the hood hinges bolt to the hood you can see a couple pop-rivits along the edge for the metal reinforcement. If I could see inside the hood I would bet it`s only a thin strip of metal being used to reinforce the hood. My drivers side has a slight bulge probably from me when I had those stiff Penstar springs on it .So even the repops wont take a lot of abuse.On a side note the 5.5" trampoline springs I measured was from the coiled part of the springs not the overall length. Overall length on these springs are about 7.5".
I have a T/A hood and it bow's on one side too. I tried 2 different sets of springs, finally just removed the springs, and use a rod with 2 bends in it that go through the holes in the hinge to hold the hood open.
If you want to try the trampoline springs Brad, I can bring a couple to the nats with me Brad.
No problem, I saw a guy at a show using the same idea you are. Seemed to work pretty good, probably just as easy also.
Sure am glad the T/A hood doesn't use the hood latch!
You have missed out on so much Brad. Even as much as I hit my head on that thing, I always seem to forget it's there waiting to nail me.
