Author Topic: Need some help?  (Read 8895 times)
Offline 1 sassy cuda
Need some help?
« on: April 21, 2011 - 02:12:41 PM »
I have a 73 cuda with a 68 440, recently installed a performer rpm under my holley dp 750 and have no hood clearance. I have a rallye hood and a drop base and 3" filter already. any ideas?    :stomp:
73 cuda'  4 spd  11.3:1CR  440  .030KB  balanced, Indy heads
Offline barracuda7199
  • needs a resto but having to much fun right now
Re: Need some help?
« Reply #1 on: April 21, 2011 - 06:44:45 PM »
maybe swap to a 2" filter? will the hood close with no filter?
Brandon
71 Barracuda 440 727
(O O {]{]{]|[}[}[} O O)
Offline AARuFAST
  • AARuFAST
Re: Need some help?
« Reply #2 on: April 21, 2011 - 09:27:05 PM »
 :thinkerg:   simply uninstall the performer rpm  :working:  close the lid..............kiddin
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
Offline footin70rt
Re: Need some help?
« Reply #3 on: April 21, 2011 - 11:41:55 PM »
And if the hood will close without the air cleaner, how much clearance is available?
Thomas
Driving the same 70 R/T since October 1985
Native of Bozeman, MT
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Need some help?
« Reply #4 on: April 22, 2011 - 08:07:40 AM »
Ok, here's my weird options on this situation....
Like already mentioned, a shorter air filter is the cheapest solution.  That way you get to keep the rallye hood.
If you absolutely need to keep the 3" filter....
Aftermarket fiberglass Cuda hood with a Six Pack scoop or get a flat hood and cut it for a shaker but have the shaker bubble attached to the hood.  This way you PERHAPS may get the clearance you need plus get some fresh air with a semi stock look.  It depends what look you want.
You can also go for a Ram Air box that has the hoses that lead to the front of the car that allows cold air to be drawn in...  :2cents:
http://www.summitracing.com/parts/SPE-728/
What ever you do, see how much clearance you have with the hood you use to avoid any  :bricks1: and  :swear: .
Offline AARCUDADEN
Re: Need some help?
« Reply #5 on: April 22, 2011 - 08:44:54 AM »
:iagree: find a nice aftermarket fiberglass hood and forget about it and besides your Cuda would look good with a six pac scoope  :thumbsup:
Dennis,Ohio
Re: Need some help?
« Reply #6 on: April 22, 2011 - 05:15:57 PM »
thanks guys for the replies. I will use clay this weekend to see if I have 2".  The top carb flange is level with the top of the fenders  :banghead: should have measured before the intake purchase . I would like to get a spectre dual snorkel kit for cold air.
Re: Need some help?
« Reply #7 on: April 22, 2011 - 05:57:56 PM »
I don't know if this company is any good, but they have a fiberglass Six Pack hood...
http://www.up22.com/barracuda.htm#BR-125
Make it look like this bad boy...this car has clearance issues too!
Re: Need some help?
« Reply #8 on: April 22, 2011 - 07:13:03 PM »
I don't have personal experience with UP22, but have heard a few disparaging remarks about their quality over the last couple years.  :2cents:
Offline Road_Runner
Re: Need some help?
« Reply #9 on: April 22, 2011 - 09:03:08 PM »
This is what I ran under my Roadrunners airgrabber hood with a fairly tall Torker intake:
http://www.summitracing.com/parts/EDL-1002/
In my experience, if this won't clear your stock hood with the rpm intake, nothing will.  Plus, it would be a whole lot cheaper than swapping intakes again or a new hood.
Later, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline JS27N0B
  • Member since Jan 28th 2003.
Re: Need some help?
« Reply #10 on: April 22, 2011 - 10:00:26 PM »
If you use a shorter filter and it now clears try a K&N air cleaner lid so you won't lose so much air flow.
2013 Tige' RZR 343hp
Re: Need some help?
« Reply #11 on: April 23, 2011 - 12:24:16 AM »
Ugghh...here's a pic of what I was trying to post before!
Offline Road_Runner
Re: Need some help?
« Reply #12 on: April 23, 2011 - 09:54:25 AM »
I've always wondered about driving behind a scoop like that.  I remember a chopped 32 coupe at a show that had a 671 blower sticking through the hood and you literally couldn't see straight ahead from the drivers seat.  I don't know how the owner drove that safely on the street.  The Sox Cuda wouldn't be that bad, but forward visibility would still seem to be affected.  Just curious.
Later, Jim
Re: Need some help?
« Reply #13 on: April 24, 2011 - 03:55:57 PM »
the other option is to run the Holley 330-14 SD intake , it is much lower , there is a strong market for the RPM so you can resell that
Re: Need some help?
« Reply #14 on: April 25, 2011 - 10:46:01 AM »
I managed to modify the drop base I have and a short k&n so the hood closes now.  In the future I now know to ask here before buying parts!  :cheers:
