Author Topic: Do I need to keep the seat mounting brackets that are under the floor pan?  (Read 780 times)
Offline lemming303
  • San Antonio, TX
I'm in the process of cutting the floor pan out and noticed the brackets welded to the underside. Should I keep those or will the new pan have them?
Kevin
73 Challenger Rallye - first project
Offline 72cudamaan
My replacement full pan had them already. But you might want to keep them, just in case.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline Challenger III
Mine had them already installed also.
Mike    Yakima, Washington
Resto Thread:  http://www.cuda-challenger.com/cc/index.php?topic=66668.0
Offline RUSTY Cuda
  • One big step foward!
Bought my pans quite a few years ago they did NOT have them, keep em just in case! Rich.
Offline pywell
  • Autobody Technician
    • PPC Customs
Just did mine and they DO NOT have them!
Offline lemming303
  • San Antonio, TX
So which brands did y'all buy? I'll go for the one with the brackets...
Kevin
Offline 72cudamaan
I think full pans have the brackets and the 1/2 pans do not have them.
Check with Dave at Roseville, he will know
Offline RUSTY Cuda
Didn't have full repros when I did mine. I'd go full if you can, save a ton of welding on the center seams where it meets the tunnel.Then everything is spots like orig.
Might have to save the console mounts though, are they available on the new pans? Rich.
Offline pywell
    • PPC Customs
I would go full aswell if you could, i am in the middle of welding that seam... SUCKS. Doable but sucks.
Offline 572b1cuda
mine were the older 2 piece and did not have the brackets either, i think most of the newer pans have the brackets ,i know the full floors do. i would go with the full floor also, the only problem is if your car is a 4 speed you will have to cut that nice new floor anyway :crying:
Offline lemming303
  • San Antonio, TX
I was planning on buying the full pan. My car is an auto so no cutting!  :ylsuper:
I saved the console mounts too.
Thanks for the help yall!
Kevin
