Author Topic: Firewall question  (Read 1300 times)
Offline spamtank
Firewall question
« on: April 23, 2011 - 09:24:15 PM »
Have something on the firewall of my 1970 Challenger SE with AC.
I believe that I'm looking at the heater box drain.  Can someone confirm that?  Is that the stock configuration of that part?  See photo below:
Thanks for looking.
Rick, Manchester, NH
1970 SE 383 2V AT Challenger
1977 M882/W200 Power Wagon
2013 RT Plus 6M
Re: Firewall question
« Reply #1 on: April 24, 2011 - 09:12:40 AM »
Picture doesn't show heater cable hole.
Offline spamtank
« Reply #2 on: April 26, 2011 - 08:01:45 PM »
 :thumbsup:
Thanks,  That helps a bit.
2013 RT Plus 6M
Offline peterro
  • 70 Challenger in progress...
    • The Pistonhead
« Reply #3 on: November 10, 2011 - 11:54:32 PM »
Sorry to resurrect this thread but can someone point out the heater cable hole on the picture?
Also, I have a question about the AC vacuum hole under blower fan. Is that the hole for the source vacuum?
Thanks.
Offline peterro
    • The Pistonhead
« Reply #4 on: November 13, 2011 - 08:44:50 PM »
Is the hole below the reverse light hole on the left of the master cylinder for the AC cable? That's the only hole I could find on the picture that wasn't labeled.
Offline swede-cuda
« Reply #5 on: November 15, 2011 - 06:37:30 AM »
 :wave: yes on my car the ac vacuum hole has a grommet in it ,mounted with 3 screws.my grommet has 2 holes in it,one hole has a bit of hose molded in it,thats where the water valve cable goes through.hole 2 is for vacuum source,on my -70 cuda it goes to a nipple at the rear of the carb base plate(holley 4367). other cars has only 1 hole in the 3 screw grommet,for vacuum source.those cars has the water valve cable coming through the insulation retainer hole next to the clutch safety switch hole. theres a good thread about this somewhere on here.one thought on that thread is,manual brakes =2 hole grommet? if i remember right no one came up with a final answer to why there are 2 versions.  :swaying:
