Author Topic: "GOLDEN COMMANDOS"-"GOLDFISH"  (Read 59330 times)
Offline Brusco
  • GO GO GOLDFISH !
Re: "GOLDEN COMMANDOS"-"GOLDFISH"
« Reply #165 on: June 01, 2011 - 06:47:12 PM »
Hello friends,I thought I would update you on my engine dyno that was scheduled for 1pm today.First, let me say (and you can quote me here).ALWAYS TRUST YOUR INSTINCTS! Second, let  me say that when I first brought my megabucks (well megabucks to me) motor back from Colorado I noticed when I put on the motor mounts that the alternator brackets off of that same 273 wouldn't work.The bracket is now about 3/4" too narrow to reach from the head to the front of the water pump.I attributed that to having an A/C water pump (it is 3/4'wider) put on because it moves more water even though it is the 3/4"too deep that accounts for the bracket issue.Let me also tell you (here comes the trust your instincts reference) that upon further inspection of that whole "ok now I need an complete set of alternator brackets for a 340 to overcome this water pump dilema".I know this will fit just by looking because I had a '71 340 that I built from the ground up,bolt by bolt.Anyway, next I find on the front of the block on lower right side (looking at it from the front) of the timing chain cover & water pump ass'y a semicircular hole that (did I say instincts?)looks like a bolt hole.(Well,half of one). I thought to myself at the time HUH? I wonder if that is a water jacket hole?(Are we getting it yet)? However,having one of the best MOPAR engine builders in the midwest at the helm I think to myself "Self,no way would Pete just leave a water jacket hole exposed, it must be just an unused bolt hole that wasn't used on the Milodon A/C race pump #16250,or the new timing chain cover.I want to make it perfectly clear that I still hold Pete in the highest of regards.That brings us up to date at the dyno shop.Marlon had to torque the flywheel I put on,the valve covers I painted, and install the distributor drive gear before dynoing it tommorow,He had it all set up and on the dyno and thought he might go ahead and put glycol in to sit over night to make sure we were leak free.Needless to say we did not have to wait overnight to see if we had a water leak.It was instantanious.Luckily the inside half of the hole was completely covered by gasket and inside wall of the timing chain cover so no glycol leaked into the oil pan.Now we are rectifying that problem so we can still make the dyno by the 1pm tommorow schedule.That minor setback could have been avoided if I had trusted my instincts.I could have fixed it long before the day of dyno setup,BUT NO!Did I mention the extra chunk of change that is going to cost me?it is still on the dyno mount and Mr.Dyno being a very excellent Mopar engine builder is on the job.Lastly let me say this "Do Not" put a 318/340/360 timing chain cover and wtaer pump on a 273.However you will have to because 273 timing chain covers are not available anymore,remember there is this bolt hole on the right side you might want to plug before you bolt on the front of the motor.I'm just sayin'.The "GOLDFISH" is, as I have said before and will surely say again has been a BLESSING, and a CURSE!  :violin:
« Last Edit: June 02, 2011 - 05:06:37 AM by Brusco »
Oooooh Barra-Barra-CUDA !
Offline Brusco
  • GO GO GOLDFISH !
« Reply #166 on: June 02, 2011 - 11:04:23 PM »
The Dyno on my 273 Commando V-8 left us happily surprised today.Here is the Peak Sweep Page showing 381 H.P. @ 6500 RPM.We could have gone over 400 H.P. had we run a sweep to 7500 RPM.That was the build spec. but I am very happy with what I saw at 6500 RPM.I did not expect more than 375 H.P. and now I know I have more just in case.Peak Torque is 337 Ft. Lbs. @ 5200 RPM. We are currently editing the video and it will be posted on the web soon.
Picture ogf graph sheet deleted for some reason. SEE WEBLINK BELOW :droolingbounce:
« Last Edit: June 08, 2011 - 09:40:51 AM by Brusco »
Offline hpe600rt
  • how sweet it is
« Reply #167 on: June 04, 2011 - 04:48:27 AM »
very cool
Offline GranCuda1970
« Reply #168 on: June 04, 2011 - 05:51:46 AM »
Nice consistant torque pattern there.
Offline Brusco
  • GO GO GOLDFISH !
« Reply #169 on: June 04, 2011 - 10:40:43 AM »
Hey thanx guys,it turned out pretty good for a little 273 that I put together the engine package by looking thru my 1999 Mopar Performance Parts Catalog that had just come out.LOL. Seems like eons ago. Brusco ps.We also decided to stop the dyno at 6500 rpm cuz after we got more than 375 we figured anything more than that was just showing off.
« Last Edit: June 04, 2011 - 10:42:21 AM by Brusco »
Offline Matt70
« Reply #170 on: June 06, 2011 - 08:50:03 PM »
Very nice Brusco! Looks like you got one mean little motor there   :burnout:
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf.
George Orwell
Offline Brusco
  • GO GO GOLDFISH !
« Reply #171 on: June 06, 2011 - 09:18:16 PM »
Thanx Matt70, That engine with an A-833 Hemi-Ratio tranny and 486 gears with 14"x 9"x 28" MT"s should do the trick for me.I am hoping to turn better than 12 sec. 1/4's.  :feedback::cheers:
« Last Edit: June 06, 2011 - 10:47:07 PM by Brusco »
Offline Brusco
  • GO GO GOLDFISH !
« Reply #172 on: June 08, 2011 - 09:37:18 AM »
Hey folks, Check out a few short takes of my engine dyno on the "GOLDFISH" engine exclusively at www.1962to1965mopar.ornocar.com/mmo72007.html .Also look around the website a bit and enjoy what they have to offer us MOPAR fans.Thanx Gary,Brusco
        :burnout:
« Last Edit: June 08, 2011 - 05:52:14 PM by Brusco »
Offline Brusco
  • GO GO GOLDFISH !
« Reply #173 on: June 11, 2011 - 09:54:59 AM »
I just locked in a tire sponsor,thanx J.R. I am going to have 3 sets to start with.The first set is on the car.They are 28"x10.5"x15".Way too wide for NHRA sanctioned events(tread sticks out beyond fender flares) but will be good for burnouts and exhibition runs (and the occasional street romp).The other two sets I think I will use are going to be 9" wide and I would like to go with 26",28",and/or 30".Can anyone tell me how much the diameter is going to affect my 4.86 rear gear ratio?I'm not sure if I remember right but the 28" should keep it the same but how do I figure the ratio with smaller or taller tires?And why is it so hard to find slicks for 14" rims? The "FISH" came with 13's and the G.C.'s used 14's on the rear.
 :feedback:
Offline Brusco
  • GO GO GOLDFISH !
« Reply #174 on: June 19, 2011 - 08:22:21 AM »
HAPPY FATHERS DAY !
Offline Brusco
  • GO GO GOLDFISH !
« Reply #175 on: June 24, 2011 - 11:00:44 AM »
I just received word that the first major news article on the "GOLDFISH" V.2.0 will be published late next week after I approve the final draft.I will post a link to the article when it is released.
Offline TreeFrog
    • TreeFrog
« Reply #176 on: June 24, 2011 - 04:15:02 PM »
 :thumbsup:
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline hpe600rt
  • how sweet it is
« Reply #177 on: June 25, 2011 - 03:41:10 PM »
cool would love to see it
Offline Brusco
  • GO GO GOLDFISH !
« Reply #178 on: June 25, 2011 - 04:04:41 PM »
I got the first two paragraphs last night to review and edit.I like Ray's writing style , all I can say is his perspective is interestingly unique .
« Last Edit: June 25, 2011 - 04:11:22 PM by Brusco »
Offline sadil340
« Reply #179 on: June 25, 2011 - 04:30:18 PM »
Am I doing something wrong with Photobucket? I can't get more than a few seconds of video to play before it starts buffering again. My network is pushing 6 megabits so it's not at my end...
1970 Cuda 340 4-speed
3:55 SureGrip
Owned since 1974
Bought from original owner
