Author Topic: Cuda/ Challenger Parts For Sale - Update 5/1/11  (Read 3879 times)
Offline crocha617
« on: April 28, 2011 - 08:51:29 PM »
V8 K Frame - Nice Shape  - $80
V8 K Frame w/ Disc Brake Setup (including rotors /calipers) & Front Sway Bar setup - Surface Rust needs Restore - $300 $250 (came off 1970 barracuda convertible)
440 dated 1973 standard bore all machined ready to assemble cylinders & all bearings surfaces are clean, new freeze plugs installed, a little surface rust start on outside of block only - Have maincaps, pistons, steel crank, rods, new bearings, new rings, new cam, new lifters, oil pump, bolts, - $800
$725
Big Block 23 Spline 4 speed trans with mounting block B/E Style - $350 -SOLD
143 Tooth neutral balance flywheels - I have 2 of them $75 each
1970 -74  Challenger doors both are decent with very little rust - $150 each (1 right/1 left)
1970 Challenger Headlight Bezels - 2 passenger sides $75/ $50
1970 Cuda rear convertible panel  (driver side) white with speaker hole - dirty - $50
Challenger Black front door panel sets. One set looks like brand new but have 2 small cracks on the edges $150/pair- SOLD. The other set has wood inserts, no cracks but scratches decent for driver though. $120/pair
Challenger Passenger Door Panel in White Repro - Brand new never on a car - $150
E-body Cowl Patch Panel - The piece under the wiper moter with the drain. - $100
E-body 2 speed wiper motor linkage - $30
B or E- Body ? Wiper Arms / Wiper (4 pieces) - $30
E-body Rear shackles -  $25
E-body Auto Console top plates - (2 available) - $20 each
E-body Standard Gauge switch Panel - $35
E-body 10" rear Brake drums - $30 pair
E- body - Front Drums 11" with spindles - $40 pair
I need to move some of this stuff to make room. I'm open to offers I will do package deal for multiple items just try me. crocha@walshgroup.com - I will ship anything as long as you pay for the shipping.
See pictures of most items below. I have paypal
https://picasaweb.google.com/107079258862899267356/Parts?feat=directlink
« Last Edit: May 02, 2011 - 12:58:56 AM by crocha617 »
Offline chaps70rt
  • 70 Challenger R/T Hardtop in Progress (Canada)
Re: Cuda/ Challenger Parts For Sale
« Reply #1 on: April 28, 2011 - 10:52:23 PM »
I am interested in the two decent black door panels for $150.   Could you send pics?   Do they need re-dying ....if so, not a problem ... doing the other pieces.
Any deep scratches or gouges?
Thanks ... CHAPS
Send me PM if you like?
White 1970 Challenger R/T
440 - 4BBL - Shaker
Daily Driver - 2014 Dodge RAM 1500
Stouffville, Ontario Canada
Offline Matt70
« Reply #2 on: April 28, 2011 - 11:13:56 PM »
Where are you located?
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf.
George Orwell
Offline crocha617
« Reply #3 on: April 29, 2011 - 07:00:24 AM »
I'm in Foxboro, MA.
Offline crocha617
« Reply #4 on: April 29, 2011 - 07:05:08 AM »
These are the nicest door panels I've ever seen as far as finish go , there is no chaulking or deep scratches & I don't think they even need redying but they do have some small cracks around the edges that should be repaired. There may be a couple of very faint scratches in the face. I just noticed the picture is blurry I can take some more this weekend.
Offline chaps70rt
« Reply #5 on: May 01, 2011 - 09:48:41 AM »
Pls send me a Personal Message ..... with pics of the door panels with close ups of any issue areas.    Thanks .... CHAPS
440 - 4BBL - Shaker
Offline chaps70rt
Re: Cuda/ Challenger Parts For Sale - Update 5/1/11
« Reply #6 on: May 05, 2011 - 07:41:56 AM »
If you change your mind about selling the door panels, please let me know.    Thanks ..... CHAPS
440 - 4BBL - Shaker
Offline JonS
« Reply #7 on: May 14, 2011 - 10:56:50 PM »
Chris,
Do you have better pictures of the passenger door?  I'm assuming this is a door shell, yes?  I have a door and a patch to put on the bottom of it; but if your door is more "decent" than mine then I'll grab yours :)
Jon
Offline crocha617
« Reply #8 on: May 15, 2011 - 06:46:17 AM »
I will get you some later today and take a good look at it again. It has a handle on it as well and I may have the glass for it as well.
Offline 422STROKER
  • Member Since 6/3/06
« Reply #9 on: May 15, 2011 - 12:20:26 PM »
Does the k-frame with disc stuff have the LCA's as well?
Tom
Tom
Offline crocha617
« Reply #10 on: May 15, 2011 - 03:50:09 PM »
Chris,
Jon
The door is pretty decent no major rust or bends. It's definately got it's share on nicks and scrapes. From the decals on it I assume it came off a 72-74 but will fit any year. The bottom lip has very light surfcae rust on it, there is one spot in the center lip the is thickened like it is bubbles a bit. Look at the pictures in the album it is the yellow door way at the end last 9 pictures or so. My camera is screwed up so it looks pink in spots (it's all yellow).
Let me know if you want it and I can try and get you a shipping quote my guess would be like $50-75
« Last Edit: May 15, 2011 - 03:54:02 PM by crocha617 »
Offline crocha617
« Reply #11 on: May 15, 2011 - 03:52:16 PM »
Tom
Yes Tom it is complete except I took the power steering box and a some steering off it.
It has sway bar, upper & lower control arms, rotors calipers, strut rods, & all hardware. See the pictures in the album. By the way the pictures make the stuff look alot rustier then they are in person.
« Last Edit: May 15, 2011 - 03:54:48 PM by crocha617 »
Offline JonS
« Reply #12 on: May 15, 2011 - 09:17:48 PM »
Chris,
I'd like to have the door.  I'll shoot you a  PM.
Jon
Offline crocha617
« Reply #13 on: May 15, 2011 - 10:38:09 PM »
I sent you my info and once I get your address I'll get some shipping prices.
Thanks, CHris
Offline cudaized
    • Ola's `cuda page
« Reply #14 on: May 18, 2011 - 09:00:31 PM »
Chris,
I'll trade you for a 781 torsion bar?
Ola
1970 `cuda340 convertible 4-speed Rallye Red with Red interior
www.cudaized.com
1970-71 Plymouth and Dodge E-Body Convertible Registry
www.ebodyconvertibleregistry.com
