Author Topic: Backspacing calculation cornfusion  (Read 787 times)
Offline shadango
« on: April 29, 2011 - 01:24:20 PM »
 :clueless:
Ok....I pulled one of my back rims....a chinese knockoff (far as i can tell) of a Weld drag lite.
I say knock off cause it is marked "made in china" and  doesnt say weld anywhere on it.
All it says is  T-531.
Anyhoo.
Trying to check the size and backspacing in prep for new tires....
The wheel is stamped 15x8.0  and then says   0 offset
Now from what i can find online, this should be a 4" offset wheel.
But I took a straight flat piece and laid it across the edge of the back side of the rim and measured to the mounting flange surface,.....and got 4.5" (give or take an 1/8")
For the front wheels (which are the same style and number but different size), they are 15x7, offset 0...but that backside measurement is 3 15/16".
Online I read an article that says that for a zero offset wheel, the backspacing is one half the width.
So WTF!!!
I also found that the wheel says "max diameter tire 28"...... so that will limit the size of tire I get obviously.
Thoughts on the backspacing question?
***update a couple years later -- LOL ---its an ULTRA "Nitro" wheel......
« Last Edit: July 22, 2013 - 11:41:47 AM by shadango »
Offline Katfish
  • 70 Challenger
Re: Backspacing calculation cornfusion
« Reply #1 on: April 29, 2011 - 04:50:57 PM »
I ran into this problem when looking for Mustang rims.  From what I found, the offset is related to the inside of the bead where the tire mounts, and the BS is to the outside of the rim.  From what I found the backspace is usually 0.5" greater than the offset.
Sounds like that's what you found also.
Offline 72cudamaan
« Reply #2 on: April 29, 2011 - 05:15:08 PM »
   :iagree:  Yes, you measure to the inner edge of the bead lock.
If I cant fix it, it's broke
Andy  (phukker whither)
