I need a little Tire size & selection help
Author Topic: I need a little Tire size & selection help  (Read 7061 times)
Offline Strawdawg
    • Vortex Buicks
Re: I need a little Tire size & selection help
« Reply #15 on: May 04, 2011 - 09:49:05 AM »
275/50-15 is effectively a 26" tire as opposed to the 60 series....does not have the sidewall but can be a little wider.   It does not bite as well as the 60 series as it has less flex in the sidewall and is a little shorter footprint.   If you are not making a lot of power at lower rpm, it is a good street choice.
« Reply #16 on: May 04, 2011 - 09:58:50 AM »
275/50 is a common drag tire size, but a not a very common street tire size. I wouldn't recommend going there.
200 rpm difference for a 275/60 isn't that much. It may allow you to add 3-5 mph at the same rpm speed. But, I'd receommend you check Summit and see what they list for 255/60 or 245/60. I think that Mickey Thompson offers this in ther ST line, which is actually a better tire than BFG and may be in stock at Summit.
Offline wally426ci
    • maryland mopars
« Reply #17 on: May 04, 2011 - 10:27:38 AM »
My dilema lies up front:
What do you think of 215/65r15 or 60r15 up front?
In comparison to 225 since it is not available right now. Im gonna get some more life out of my rear tires for financial purposes.
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline Strawdawg
    • Vortex Buicks
« Reply #18 on: May 04, 2011 - 11:10:07 AM »
seems small for a big block up front.  Depends if you want handling, or you just want the look
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #19 on: May 04, 2011 - 01:24:28 PM »
215 shoud work fine, if I did it over again, I would go with a 215/65-15 and a 275/60-15.
I have 15x7 with 235/60-15s up front now, too wide for what Im looking to do now.  On the back 15x8 with 275/60-15.  Good luck with what ever you decide.
Don
Member Since January 14, 2002
Offline shadango
« Reply #20 on: May 04, 2011 - 06:18:58 PM »
Don
Hey Don
Would you clarify what you are trying to do now to make you feel like the 235/60/15 up front is too big? You are running the combo I am considering....
Offline wally426ci
    • maryland mopars
« Reply #21 on: May 05, 2011 - 08:53:07 AM »
Ok here is the chart i was using for tire height:
http://4wheelonline.com/BF_Goodrich_Radial_TA_.150465.541113
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline shadango
« Reply #22 on: May 06, 2011 - 01:47:54 PM »
Thanks...seems about the same as other numbers I have found....
Went to a cruise last evening for a bit and there was a 70s monte carlo with the 275/60/15 on them and they do seem big, and thats a big car.......there was a 68 camaro with the 255/60/15 and they seemed small although bigger than my 235s.......LOL
Offline wally426ci
    • maryland mopars
« Reply #23 on: May 06, 2011 - 06:12:22 PM »
I'll try and get a picture of my 255's on my Challenger for ya. They looks sweet.
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline mojavered
  • Someday!
« Reply #24 on: May 07, 2011 - 01:17:21 AM »
I like the 275's on the rear...but the 225's up front just look funny, IMO.  I did not want to wait for the 235's and went with the 225's and they just do not look right.  If I could do it all over again, I would get the 235's.
Jason
« Reply #25 on: May 07, 2011 - 08:54:10 AM »
I think he is referring to going 1320 feet as fast as possible and not as concerned about fast cornering.
Offline wally426ci
    • maryland mopars
« Reply #26 on: May 07, 2011 - 02:41:15 PM »
As in, they look small funny?
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline hotrod98
    • Maniac Musclecars
« Reply #27 on: May 11, 2011 - 03:30:26 PM »
The best all around tire size for an e-body is P235/60R15's on the front on a 7"rim with 4" backspacing and P255/60R15's on the back with an 8" rim with 4 1/4 to 4 1/2" backspacing. You can go as wide as a P275/60R15 on the back with no modification as long as the rear differential is centered. P245's on the front start to rub and P295's on the back can tend to rub sometimes on some cars.
I've owned dozens of e-bodies and when going with stock rims, this is the setup I've used almost every time. B-bodies are a little more forgiving.
On my Superbird I went with P245/60R15's all of the way around on 8" rims and they fit and look fine.
1971 Cuda, Tor-red, Bench seat
1971 Cuda Drag Car
1973 Cuda Clone, EFI/OD Limelight
1970 Superbird (Yes, it's real) Black Ice
1971 Barracuda Sassy Grass Green (sold)
1970 Challenger RT SE 383 Plum Crazy
1969 Road Runner Hardtop
1968 Road Runner Coupe (sold)
www.maniacmusclecars.com
Offline 360FISH
  • BS23H3B567746
« Reply #28 on: May 13, 2011 - 12:08:26 AM »
I really like the 275/60...  jacked up and full of fight...   :ylsuper:
1973 ‘Cuda   Semi-Pro Touring
360 SB - 518/OD auto tranny - FAST EZ EFI - Edelbrock Fuel sump - HHR fan
Hella H4 headlights on relays - 97 Dodge Avenger seats - Chin spoiler - Bumpers pulled in to ’72 offset
Build: http://www.cuda-challenger.com/cc/index.php?topic=74674.0
Offline Cuda54
« Reply #29 on: May 13, 2011 - 01:59:31 PM »
I like the set of Crager SS mags 8"x15" with a 5"BS 235-60 up front and 275-60 on the rear. This on my 72 Cuda it is B-5 with a white 440 hockey stripe . But I would still like to go wider on the rear. I might have to add a 4 link to get it to hook up then I would just tub it too. And add a narrowed diff and wider tires should help. And it will look good too. :bigsmile:
