Author Topic: carter 2brl rebuild  (Read 1538 times)
Offline Jocigar
Re: carter 2brl rebuild
« Reply #15 on: May 31, 2011 - 09:40:40 AM »
hey guys, new problem....when turning over the engine the 2 brl carb overflows gas from on top, where there is a spring loaded plunger on a rocker arm.
I think the needle attached to the float most have found some dirt ... anyone in agreement or are there other issues at hand?
can this be fixed without removing the carb again?
thx!!
Offline Challenger6pak
« Reply #16 on: May 31, 2011 - 05:30:59 PM »
It may be the needle not seating.  It also could be a out of adjustment float or a bad float.  You can check it while the carb is on the car.  Just unscrew the carb top and take it off.  Make sure you don't drop anything down into the intake.
