Author Topic: 2 Pipe Plugs in rear of 440 Block  (Read 557 times)
Offline 7Dcuda
« on: May 04, 2011 - 09:34:59 AM »
Whats the purpose of the 2 pipe thread plugs in the rear of a 440 block next to the cam plug?
Re: 2 Pipe Plugs in rear of 440 Block
« Reply #1 on: May 04, 2011 - 10:09:32 AM »
the lifter galleries are drilled through the block after the block is cast , the pipe plugs close the hole into the lifter gallery
Offline 7Dcuda
« Reply #2 on: May 04, 2011 - 10:21:28 AM »
Ok, thanks...makes sense.  Obviously an oil leak source though huh.  Guess you should use some pipe thread tape on them?
« Reply #3 on: May 05, 2011 - 05:29:17 AM »
definatly  :2thumbs:
