Author Topic: cuda on the rottiserie, what do i need to do?  (Read 799 times)
Offline leanburn
« on: May 04, 2011 - 06:50:42 PM »
it started out as redoing the trunk pan and it snowballed. now it's a complete nut and bolt rottiserie. i stripped the car and took it to the body shop and i'm going to assemble it, ive never done anything to this extent so i will be asking alot of questions. my first question is when my car is done at the body shop [ rolling chassis] what is the best/ most effiecent order to reassmble. i would assume to do all steering components first so it is somewhat mobile then everything in the engine compartment except the engine, dash/ gauges and then electrical??
Offline mopar12372
    • mopartech
Re: cuda on the rottiserie, what do i need to do?
« Reply #1 on: May 04, 2011 - 08:32:11 PM »
 imop
do the suspension get the car on the ground
install windows
 install the engine and drive train /
accessories  ect
wire up the car stock or after market
install fuelsystem
install the material for sound  what ever you choose / install interrior
install all exterior parts
goback to engine and fine tune it for start up . test lighting ect start up
look over car for loose nutz and bolts
RESTO PICTURES
« Reply #2 on: May 04, 2011 - 10:00:23 PM »
Do it just like the factory did it.
Once you get it home, get the fuel/brake lines installed as well as the fuel tank.  Get the booster/master installed along with the prop valve.  Install the heater box and all of the weatherstripping.  Run the wiring throughout the car and install the headliner.  If the bodyshop didn't spray the rad support blackout, do that before anything is installed in that area.
Install all the engine compartment assessories while the engine is out.  There is alot more room to work that way.  Install the splash shields and undercoat the wheelwells.
Finish the bigger components as complete assemblies.  Assemble the dash and install it all in one piece.   Completely assemble the rear end housing along with the springs.  Roll the whole assembly under the car and bolt it up.
The front suspension can be rebuilt and installed on the K-member.  Once the engine and trans are done, bolt them up to the K as well.  Using a cherrypicker, lift the whole front of the car up in the air to install the engine/trans/K-member all at once from the bottom.
Finish with the rest of the interior/exterior trim and lastly install the front/back glass.
There is no right or wrong way to do it.  Check out RestoRick's website for a really good assembly checklist.
« Last Edit: May 04, 2011 - 10:08:30 PM by burdar »
Offline leanburn
« Reply #3 on: May 04, 2011 - 10:11:04 PM »
thanks burdar, thats pretty much what i had in mind.
