Author Topic: 340 cast crank/904 converter weights?  (Read 5546 times)
Offline Milkmann
« on: May 04, 2011 - 09:22:15 PM »
Got the correct harmonic balancer on my cast crank 340, I will need to add weights to the torque converter. T-Flite Patty on Ebay has a kit, but does anyone know how much weight to add and where to add it? I have access to a scale which will weigh in grams, so I can get the weight right, but I don't know for sure where to put them.
Re: 340 cast crank/904 converter weights?
« Reply #1 on: May 04, 2011 - 09:27:52 PM »
I believe you can buy a flex plate that wont need to mess with the verter
Offline Milkmann
« Reply #2 on: May 04, 2011 - 09:48:56 PM »
If you could direct me to the proper one for a 340 cast crank I would appreciate it. A 340 is different than a 360(I have been told).
I can find flex plates for 340/727 but none listed for 340/904. Do the 727 and 904 converters have the same mounting bolt pattern? I looked at a different 904 out of a car, it appeared that the converter mounting bolts were on a 10" circle. Would this apply to all 904's?
 :clueless:
« Last Edit: May 05, 2011 - 08:52:26 PM by Milkmann »
Offline 422STROKER
  • Member Since 6/3/06
« Reply #4 on: May 07, 2011 - 09:17:50 PM »
I think I have one of the 340ext 904 flexplates in my basement if you can't locate one.
Tom
Tom
Offline Milkmann
« Reply #5 on: May 08, 2011 - 09:34:58 PM »
Tom
Check and see if you have one for sure, and let me know what you want for it. I don't think they wear out very quickly. We are having 'puter problems, so no email, post back here if you have one and how much you want.
Offline tactransman
« Reply #6 on: May 09, 2011 - 11:21:01 AM »
Here is another link for the flexplate...  904 and 727 are the same. http://www.summitracing.com/parts/BMM-10235/
The amount of weight is TWO 25 gram weights.
Terry-tactransman
Union, Mo.
Offline 422STROKER
« Reply #7 on: May 09, 2011 - 06:38:06 PM »
I have this in the box unopened.  PN B&M 10234  I thought the 340 Ext balance took a different flexplate for a 904.  They don't seem to stock this part anymore.
How about $40 + shipping  IIRC it was 80+ when I bought it.  Let me know.  Not sure the best way to ship it? :feedback:
http://www.summitracing.com/parts/BMM-10234/
Tom
Tom
Offline tactransman
« Reply #8 on: May 09, 2011 - 07:01:03 PM »
They don't stock it any more because the 10235 took it's place (904/727) The balance has nothing to do with 727 or 904, the flex-plate has a "tri-bolt pattern" so it fits them both 904 and big pattern 727. The small bolt pattern 727 is the same bolt pattern as a 904.
Terry-tactransman
Union, Mo.
Offline 422STROKER
« Reply #9 on: May 09, 2011 - 07:41:40 PM »
Gotcha. :2thumbs:
Tom
Tom
Offline Milkmann
« Reply #10 on: May 09, 2011 - 10:26:26 PM »
So the 10234 is only good for a 904 tranny or small 727, and the 10235 is good for either 904 or 727? Am I understanding correctly? If I were to want to go to a 727 trans at sometime in the future, is it likely I would have converter fitment issues if I had the 10234 plate? What determines small or large converter on a 727?
Thanks for your advice.
Offline 422STROKER
« Reply #11 on: May 10, 2011 - 05:18:25 PM »
If you want I can measure the bolt circles on this flex plate before you buy it.
Tom
Tom
Offline tactransman
« Reply #12 on: May 10, 2011 - 06:25:48 PM »
The 10234 will fit all 904's and all small bolt pattern 727 converters. It is a two bolt pattern/one diameter flexplate (4 holes for 5/16 bolts and 4 holes for 7/16 bolts that are used in the higher stalls) It is like the middle one in this pic, where as the 10235 is like the bottom one (12 holes instead of 8 ) with two diameter bolt patterns
Terry-tactransman
Union, Mo.
Offline tactransman
« Reply #13 on: May 10, 2011 - 06:27:57 PM »
Milkmann,if you can post a pic of your converter,I can tell you if it will fit or not.   :cheers:
Terry-tactransman
Union, Mo.
Offline tactransman
« Reply #14 on: May 10, 2011 - 06:31:26 PM »
A better pic of a 10235. The 10234 will not have the outer row of holes by the edge.
Terry-tactransman
Union, Mo.
