Author Topic: 340 cast crank/904 converter weights?  (Read 5548 times)
Offline Milkmann
Re: 340 cast crank/904 converter weights?
« Reply #15 on: May 10, 2011 - 09:28:17 PM »
Milkmann,if you can post a pic of your converter,I can tell you if it will fit or not.   :cheers:
Thanks for the offer, the converter is still in the car, it's a stock converter for a 74 318 car so I am sure it's the small one. The whole tranny is not very big-but I am a farmer so I'm used to working on tractors and Class 8 trucks.
Am I correct to assume that only a super-HD 727 would have the large bolt pattern converter? Probably only OE on big blocks? Would there ever be any reason for me to need the large bolt pattern converter behind my mild 340? If I was ever to do anything radical to the motor, I would make sure to have it internally balanced and the offset weighted flexplate would no longer be needed.
I am thinking that there is no reason that the #10234 offered to me would not serve me well for any setup I might use with the present cast crank. If there is some reason it might not work, I'd rather hear it now instead of later.
This emoticon applies to me-alot--- :clueless:
Offline barracuda7199
  • needs a resto but having to much fun right now
« Reply #16 on: May 10, 2011 - 09:53:09 PM »
every aftermarket performance converter i have seen uses the smaller bolt pattern. not saying i have seen them all but i have seen my fair share of them having 9 mopars between me and the old man to wrench on. the #10234 should be just fine for what you are wanting to do.
Brandon
71 Barracuda 440 727
(O O {]{]{]|[}[}[} O O)
Offline tactransman
« Reply #17 on: May 10, 2011 - 10:21:59 PM »
:iagree: You have a 904 so you are defenitly ok with 10234 plate. Even if you go to a 727 .
Terry-tactransman
Union, Mo.
Offline Milkmann
« Reply #18 on: May 10, 2011 - 10:39:57 PM »
Thanks for the reassurances. I doubt I'd change to a 727 anyway, if I need to do anything with the trans I'll either beef up the 904 or go to a clutch.
This one works good now except for the slight shaking.
Offline Trogdoor
  • Newbie
« Reply #19 on: September 01, 2011 - 12:02:29 AM »
Does 72Challorange still have the 10234 flexplate for sale?
Offline 422STROKER
  • Member Since 6/3/06
« Reply #20 on: September 01, 2011 - 08:26:43 PM »
No, I shipped it to Milkmann a while back.
Tom
Tom
