First check the connections for corrosion at the tail light bulb and socket. The socket itself provides a ground for the system so make sure that is clean. Check the wiring at the bulkhead (on the fire wall) to see if there is a loose connection with a wire. It sounds like a grounding issue and they are always fun to figure out. Good luck.
