Author Topic: Timing cover seal install?  (Read 654 times)
Offline CUDA JAS
  • vroooooom!
« on: May 07, 2011 - 09:40:59 PM »
Anyone have any tips on installing the timing cover seal on a smally (the seal around the crank snout).
My timing cover gasket kit came with a think felt washer...is that to cushin the timign cover while I drive in the seal????
Thanks,
Jsson
74 'cuda 360/727
Just call me a gearhead!
Re: Timing cover seal install?
« Reply #1 on: May 07, 2011 - 10:57:30 PM »
the felt gasket is used in farm equipment / high dust environment , not needed for street use
you need a seal driver or or a block of wood to spread the load over the entire seal as it is driven in so it will go in straight
Offline CUDA JAS
  • vroooooom!
« Reply #2 on: May 10, 2011 - 09:59:49 PM »
Thanks,
Jason
74 'cuda 360/727
Offline jimynick
« Reply #3 on: May 10, 2011 - 10:16:45 PM »
 :iagree:  Princess Auto and spend a wee bit more and buy the metal set, it'll drive bearing races, too. A dab of Lubriplate on the outside and on the inr lip is a good thing too. Listen for the sound change when it seats. RTV at the surfaces where it meets the oil pan.
Offline UKcuda
  • Tell them I'm on my way
« Reply #4 on: May 11, 2011 - 04:23:33 PM »
I need to do mine as well.  I remember the last one I did was with the timing cover on the bench and it was really tight to get in.  Anybody got any special tips on doing this in situ ??
'72 'cuda
