Author Topic: My new stroker burning oil ***Engine pulled***  (Read 28489 times)
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
Re: My new stroker burning oil (video)
« Reply #15 on: May 09, 2011 - 03:01:42 AM »
the one we got when disassembled had tapered cylinder walls & over .008 piston wall clearance , no way the rings could seal it
Wouldn't it show from the start then? Why after 250 miles? I spent months on the shortblock so I'm sure about clearences, ringgaps
and openingpositions, the only thing concerning the shortblock I can't stand for is the machinework.
I also have to admit I didn't check if the intake aligned with the heads, stupid thinking that eddyheads and intake would match like a glove.
Per
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Offline ireland383
« Reply #16 on: May 09, 2011 - 09:16:07 AM »
I second the idea that you have a sucking oil situation.  Pull the intake and check the runners for oil.
1971 Plymouth Barracuda
Offline BIGSHCLUNK
« Reply #17 on: May 09, 2011 - 10:00:30 AM »
Per, anything with your build has already been said. BUT man that sucks, I hope you can get it straightend out with out to much aggravation!  :crying:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #18 on: May 09, 2011 - 10:15:42 AM »
Thanks Bigs, apreciate it. Last year the new tranny after 15 miles and now this. The worst thing is that it scares me to build my Hemi for the challyproject, I'm loosing selfconfidence here.
Per
Offline dutch
« Reply #19 on: May 09, 2011 - 11:29:35 AM »
you can dump the hemi overhere.... I`ll trade you my 440....  :jumping:
no kidding mate...this really sucks.  I hope you will find the problem in the intake area  :working:
*** Bart ***
« Reply #20 on: May 09, 2011 - 01:37:08 PM »
Thanks friend  :cheers: I used the papergaskets on both sides of the valleypan without sealer so maybe maybe maybe I'm lucky.
Per
Offline 72cudamaan
« Reply #21 on: May 09, 2011 - 05:02:51 PM »
Per
Maybe, but do yourself a favor and do the compression test first. Saves the aggravation of tearing it all back apart again
if you don't find anything wrong with the intake.
If I cant fix it, it's broke
Andy  (phukker whither)
Offline Cuda Cody
  • Vancouver, WA
« Reply #22 on: May 09, 2011 - 05:10:20 PM »
 :iagree:  Start with the easy stuff that you can do while it's still together.
« Reply #23 on: May 10, 2011 - 12:17:23 AM »
I only use one paper gasket below the intake pan on the head surface , using the one above makes it too hard to get the intake on
Offline Kapteenikosmos
« Reply #24 on: May 10, 2011 - 02:05:47 AM »
Have you checked that it isn't sucking all that oil through the PVC system? Do you have a baffle on the valve cover that has the PVC valve? I kind of understood that the problems started soon after the pvc was installed?
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
« Reply #25 on: May 10, 2011 - 02:36:54 AM »
Indeed it started just after installing a PCV valve and no, my valvecovers don't have any baffleplates.
Per
« Reply #26 on: May 10, 2011 - 05:50:24 AM »
Pull the PCV out of the valve cover , if it stops you found the problem !
Offline 422STROKER
  • Member Since 6/3/06
« Reply #27 on: May 10, 2011 - 05:20:08 PM »
The PCV hose would be coated in oil as well.
Tom
Tom
Offline Cuda54
« Reply #28 on: May 10, 2011 - 08:08:49 PM »
I would plug the PCV and drive it for about 50 miles the check the plugs again and see what they look like. We had one years ago that we had to put a 3/8" tube with a 1/4" hole inside in the middle of the PCV hose. That way it could not suck as much to keep it from burning oil. You might try that to see if it help you. Some engines take longer to break in too.
Offline mojavered
  • Someday!
« Reply #29 on: May 10, 2011 - 08:12:25 PM »
I was running a Mr. Gasket PCV and just pulled it off.  The filter element inside traveled all the way through the hose to the inlet of the intake and was packed in there.  I had recently had oil start pushing out around the valley plate.  I think the clogged hose was probably part of the cause of the leak?
Jason
