Author Topic: carb butterflies catching on carb spacer?  (Read 895 times)
Offline 70 RAG TOP
« on: May 08, 2011 - 01:28:41 PM »
I am having a problem with the secondary butterflies catching on the carb spacer.  I have a stock dual plane manifold w/ 4 identical sized holes(1-11/16" diameter) I just bought a new Edelbrock thunder AVS carb, 650 CFM and I am using a 1/2" thick phenolic spacer.  The carb has 1-7/16"(primaries) and 1-3/4" (secondaries).  The holes in the spacer are 1-11/16".  Therefore there is a difference of 1/16".  When I manually open the secondary butterflies, they catch on the spacer and will not open all the way.  Did I get the wrong carb or do I have the wrong spacer?  I know that they make spacers with holes that are large at the top and taper down to the smaller hole in the intake.
Can anyone help me with this?
Offline Strawdawg
    • Vortex Buicks
Re: carb butterflies catching on carb spacer?
« Reply #1 on: May 08, 2011 - 10:01:53 PM »
I would want a spacer with holes at least as large as the blades in order not to reduce the potential flow of the carb you selected.
Open up the holes so they match the carb, or buy a different spacer
« Reply #2 on: May 09, 2011 - 01:44:23 AM »
I agree , clearance the spacer
Offline Aussie Challenger
« Reply #3 on: May 10, 2011 - 09:03:15 AM »
Open up the spacer but then the manifold will need opening up or you will have a ledge, you may have to blend the spacer secondary holes or the manifold holes so as there is a smooth flow and no restriction.   :2thumbs:
Offline Strawdawg
    • Vortex Buicks
« Reply #4 on: May 10, 2011 - 09:51:42 AM »
be surprised if the intake has a smaller opening than the carb blades
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #5 on: May 10, 2011 - 09:25:24 PM »
Weird but true if I read it right...
"I have a stock dual plane manifold w/ 4 identical sized holes(1-11/16" diameter)"
His secondary butterflies are 1-3/4".
Offline Strawdawg
    • Vortex Buicks
« Reply #6 on: May 10, 2011 - 11:04:38 PM »
Thanks, I never think about stock stuff....:)
« Reply #7 on: May 11, 2011 - 03:00:04 PM »
Since the throttle blades are round and create an arc as they open, you may only need to clearance them very slightly on the two sides of each bore of the spacer along the axis of the throttle shaft to allow the throttle to smoothly open. If there is a 1/16 difference in overall size, you only need to smooth out 1/32 of space on each side, or remove it and simple rub it with some sand paper till everythiggn smooths out. It won't take much effort.
Offline UKcuda
  • Tell them I'm on my way
« Reply #8 on: May 11, 2011 - 04:17:58 PM »
 :iagree:   But ......
I had a similar situation - you can just hog out the edge of the spacer at the top end.  It doesn't take too much and you need to try to keep everything smooth.  But instead of just where they catch you might want to go all the way round the circle/s to avoid a step between the carb base and the spacer top.
'72 'cuda
« Reply #9 on: May 11, 2011 - 05:14:23 PM »
Wouldn't this be solved with going to an open spacer instead of one with 4 holes?    :dunno:
Offline UKcuda
« Reply #10 on: May 11, 2011 - 05:37:10 PM »
Depends on the spacer I guess, it could still maybe catch at the outside edges.  :dunno:
« Last Edit: May 11, 2011 - 05:39:14 PM by UKcuda »
'72 'cuda
« Reply #11 on: May 12, 2011 - 06:43:44 AM »
An open spacer would create a few turbulance problems between the bottom of the carb & manifold.
« Reply #12 on: May 12, 2011 - 08:22:07 PM »
 :iagree: You're going from a 4 holes/barrels, to an open space then the air/fuel in the open space (In the open spacer.) trying to find which one of 4 holes to go into the manifold.  You lose velocity in the open space then create turbulence trying to get iinto the intake manifold.
