Since the throttle blades are round and create an arc as they open, you may only need to clearance them very slightly on the two sides of each bore of the spacer along the axis of the throttle shaft to allow the throttle to smoothly open. If there is a 1/16 difference in overall size, you only need to smooth out 1/32 of space on each side, or remove it and simple rub it with some sand paper till everythiggn smooths out. It won't take much effort.
