Author Topic: Small to big block  (Read 2511 times)
Offline 06Daytona
Small to big block
« on: May 11, 2011 - 09:25:04 AM »
What's involved structurally to change a 70 Challenger from a 318 to a 440? I know the motor mounts have to change, but I'm wondering if the frame needs stiffening or boxing etc. I've decided not to grab the 440 R/T at the moment, but if I can ever get a hold of the guy with the 318 car I'm sure my wife can talk him down to 5000. I want the next car that I fix up to be either a big block or a vert and verts are few and far between down here if they're Mopar. I may end up having to go through Ebag if I can't find anything down here.
1972 Cuda 340 4 barrel 4 speed that looks like a 71
2006 Dodge Charger R/T Daytona
2005 Dodge Ram 2500 Diesel 4X4
2006 Chrysler PT Cruiser Convertible (Kidmobile)
1972 Dodge Charger 318 auto
1970 Challenger 440/727 auto
1973 Plymouth Duster 340/auto (Making it Panther Pink for the wife)
2006 Honda Civic Hybrid (It doesn't save gas, it just diverts it to the Cuda/Challenger)
In desperate need of more property for my growing Mopar family
Re: Small to big block
« Reply #1 on: May 11, 2011 - 10:21:22 AM »
Structurally, nothing required, but torque boxes or sub frame connectors are suggested. Heavier torsion bars and leaf springs are nice additions too, but again, not necessarily required to make the swap. Tranmissions are family specific so your small blocks trans won't work with the big block. If you have a rear smaller than 8.75, you mihgt want an upgrade there, depending on what  you find under any car you get.
« Last Edit: May 11, 2011 - 10:22:59 AM by HP2 »
« Reply #2 on: May 11, 2011 - 11:27:06 AM »
You'll need a different radiator too.
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
« Reply #3 on: May 11, 2011 - 01:15:07 PM »
Along with parts already mentioned, A/C hoses and brackets if equiped with A/C. Also depending on what transmision is in the car you may need another drive shaft. If the 318 has a 727 or a 4 speed you should be ok. But if it has a 904 you will need another shaft or will have to have the shaft shortened.
Worlds first e-body trailer.    Severna Park, Maryland
Offline DonP1
« Reply #4 on: May 11, 2011 - 06:22:28 PM »
I thought you would need a new K member, or is that only for a Hemi? I have a 360 in my 70 Challenger (bought that way). It was originally a slant 6.
Sorry, but I have to know - please explain how she does this?
And what's a Vert?
Offline Skunkworks Challenger
  • Mopars forever!
« Reply #5 on: May 11, 2011 - 06:43:48 PM »
All v-8's except Hemi take the same k-member.  I just changed my car , originally a big block car back to big block after someone had put a 340 in it.  All the belts and hoses will be different as well as fan, spacers, brackets etc.  The exhaust pipes off your small block won't fit a bb either. You won't like changing spark-plugs in a 440. Strangely, the starters will interchange as well as flex-plates and torque converters if automatic, assuming the cranks are made from the same material.  The throttle cable very likely will have to be changes.  That's all I can think of other than what others have mentioned.  PK
The Brewmaster
Offline 06Daytona
« Reply #6 on: May 11, 2011 - 07:49:15 PM »
And what's a Vert?
I don't speak much Spanish so my wife usually ends up telling them what we're willing to pay. She's pretty good at it too. She knows the island and what the economy is like in different areas.
I knew about all the belts, hoses etc needing to be changed. I was thinking more on the structural side if it was going to be a huge pain welding in braces and stiffeners and stuff.
Vert, convertible.
Offline AARuFAST
  • AARuFAST
« Reply #7 on: May 11, 2011 - 08:43:41 PM »
 :iagree:  Torsion bars should be changed. Purchase a new flex plate. Don't need to change K frame.
Cut the top from a HT to make a vert. u won't find any in P R.   :working:
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
« Reply #8 on: May 11, 2011 - 10:17:24 PM »
Did you cut that car to make it a vert AARuFast?
Offline Matt70
« Reply #9 on: May 17, 2011 - 06:27:00 PM »
If going with a 440 six pack do the fuel lines and sender need upsized to 3/8's?   Matt
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf.
George Orwell
Offline 06Daytona
« Reply #10 on: May 17, 2011 - 07:27:07 PM »
I would think they would need to be upsized. Even if they didn't I usually change fuel and brake lines when I buy a project car, unless they're visibly new.
« Reply #11 on: May 17, 2011 - 07:43:46 PM »
I'm still running 5/16 lines on mine. I have had no problems. Of course, I don't spend time at the drag strip either.
Offline Cooter
    • christinecarclub.com
« Reply #12 on: May 17, 2011 - 08:01:16 PM »
As a standard Practice, I ALWAYS upgrade ot the larger 3/8" fuel line as I know I dumped that 440 in there and wasn't planning on babying it...
« Reply #13 on: May 17, 2011 - 08:17:36 PM »
While they will interchange, the HP Big Block starters had more windings of the electric motor than the small blocks did.
Offline Matt70
« Reply #14 on: May 28, 2011 - 08:50:31 PM »
What about the wiring harness? I would imagine they are different.  :dunno:
George Orwell
