Author Topic: Overhead Console: troubleshooting dome light  (Read 645 times)
Offline wally426ci
    • maryland mopars
« on: May 14, 2011 - 08:58:42 AM »
So for 10 years, i never put the door jam switches in. I figured this was why my light wouldn't work b/c it needed ground. Installed a switch and it didnt work. Ive switched out the dome light with different extra's and nothing!
Any idea of where i should start? I hate wiring.  :violin:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline LAA66
Re: Overhead Console: troubleshooting dome light
« Reply #1 on: May 14, 2011 - 09:35:49 AM »
 Do you have power at the door switch?
Offline wally426ci
    • maryland mopars
« Reply #2 on: May 14, 2011 - 06:05:54 PM »
I need to check, i will say that the door buzzer worked. Thats one thing that motivated me to disconnect it, possibly the most annoying sound in the world; think Dumb & Dumber.
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #3 on: May 14, 2011 - 09:19:32 PM »
The only way you would see power at the door switch is if the circuit is complete & you read it back through the bulb or buzzer. The door switch simply provides the ground. Positive power is constantly fed to the bulb, check if there is power at the socket, on a '73 the fuse is cavity #3, same as tail lights so I doubt that's the problem.
I seem to remember problems caused by a time delay relay, your car have that?
