Author Topic: post pic of pedals and over center spring location  (Read 653 times)
Offline 70cuda440
« on: May 14, 2011 - 09:41:08 AM »
I bought a pedal setup from ebay and an overcenter spring from brewers with the pin and the spring seems too long - does anyone have a picture they can post of their pedals with the over center spring?
Offline javakm70cuda
Re: post pic of pedals and over center spring location
« Reply #1 on: June 19, 2011 - 11:44:31 AM »
This is from my 70 383 4speed car. Hope it helps. If not I have everything apart right now, so I could measure if needed.
Offline 70cuda440
« Reply #2 on: June 19, 2011 - 12:38:11 PM »
Thank you - that looks about what I had - the thing is on the bench the whole thing falls apart- I finally called Brewers and they said that is normal and it will mousetrap like that when it is out of the car - he said safety wire it together and install it then it will hold together once in the car- I just welded in the 4 speed hump and z bar frame mount yesterday so now I'm ready to start messing with the pedals
Thanks again for taking the time to get a pic for me - I do appeciate the help
