Author Topic: 440-6 vrs stock 440???  (Read 2533 times)
Offline CudamanTom
« on: May 15, 2011 - 11:01:53 AM »
Hey guys,
Got a quick question.
Besides having 3-2 carbs/intake on a 440-6 what other differences are there versus a stock 440?
Can a person just slap on a 3-2 carbs/intake on a stock 440 and go?
I've heard of exhaust manifolds, rods and other parts being specifically identified for 440-6 and was just curious as to what makes it different?
Thanks in advance.
Tom
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline Super Blue 72
    • Phil's Super Blue '72
Re: 440-6 vrs stock 440???
« Reply #1 on: May 15, 2011 - 03:41:19 PM »
I always heard the Six Pack rods were bigger.
Here a good read on this engine: http://www.allpar.com/mopar/440.html
Offline 73Chally
« Reply #2 on: May 15, 2011 - 05:52:20 PM »
The short answer is yes, you can slap a 6 pack top end onto a 440 block, but there are differences to the way the 6 pack engines were built at the factory, with pretty much everything internal, such as different rods and cam shaft.  You can take any 440 block and turn it into a 6 pack with the right parts.  That's what I did.
Offline tommyg29
« Reply #3 on: May 15, 2011 - 06:13:30 PM »
not positive but maybe also a double roller chain
Offline FJ5_440
  • Wisconsin
« Reply #4 on: May 15, 2011 - 11:13:44 PM »
The original six pack engines had heavier rods and were externally balanced because of it.  It also had a different cam and several other high performance parts internally.  IMHO, a well built modern 440 with good aftermarket rods and pistons and a modern cam grind will run circles around the old engine with the sixpack stuff.  Just put a six pack set up on it, tune it correctly, and make sure you have an extra set of tires to replace the ones you smoke off of the rims.  I personally think a good 4 barrel carb is a little faster and easier to keep in tune, but nothing looks as cool on top of a 440 as the six pack set up.  (except maybe a 6-71 blower)
** Shane **
Offline CudamanTom
« Reply #5 on: May 16, 2011 - 10:27:27 AM »
Thanks so much to everyone. :ylsuper:
The info you provided helped out a bunch.
Offline Morris'_Mopars
« Reply #6 on: July 10, 2011 - 09:32:14 PM »
Mine has been fine and has stock ly rods..
Morris' Mopars LLC
Raymond, Illinois
Mopar performance at affordable prices.
Offline ksierens
    • 70 Challenger Resurrection
« Reply #7 on: July 11, 2011 - 12:54:20 PM »
Mine was too, before I parked it, I also added a purple shaft street hemi cam, cause I love the lope ;)
Kurt - SE Michigan
