Author Topic: How to Advice/Instructions, for Trunk Mount Battery  (Read 2999 times)
Offline AmazenToys
    • AmazenToys
« on: May 16, 2011 - 09:37:03 AM »
I'm considering putting my battery in the trunk, I have seen kits, but which is the best? what advice, pros/cons of doing this? I got this idea from this site, and I just purchased a blank mopar dummy battery, could be a salesman sample. So thinking put the mopar blank in place of the real battery, and mount the real battery in the trunk. Any advice, instructions, pictures that could be helpful - Thanks in Advance
1973 Dodge Challenger, Warren Michigan.
Offline ShelbyDogg
Re: How to Advice/Instructions, for Trunk Mount Battery
« Reply #1 on: May 16, 2011 - 10:34:34 PM »
I used to do this years ago and had it in my race car.  Batteries used to leak acid and get all over your trunk stuff. Make sure you use a Red Top Optima battery and use a battery box. Get a battery relocation kit and use the heavy battery cables that come with it and run it right to the starter post, then tap off of the relay for your accessories.
I would leave it up in front if I were you. If yo cruise around a lot, leave the trunk for your cooler, chairs and tools.
« Reply #2 on: May 16, 2011 - 10:49:21 PM »
Were did you get the dummy Mopar battery? I'm wanting one for the same reason.
Offline AmazenToys
    • AmazenToys
« Reply #3 on: May 16, 2011 - 11:06:47 PM »
I found at a swap meet, it was just there,  and when I looked at it it was light. I will keep my eye open for you too.
I took some pics you asked for, try to get them posted soon.
Offline Travis72
« Reply #4 on: May 16, 2011 - 11:58:30 PM »
Do you race the car at NHRA tracks?  If so that adds a lot of complexity.  If you still want to move the battery I would recommend an Optima type battery that won't leak or outgas.  Be aware that it's kind of an expensive swap to do just for looks (battery cables, etc.).
Travis
72 Cuda
Offline AmazenToys
    • AmazenToys
« Reply #5 on: May 17, 2011 - 12:07:25 PM »
I'm a daily driver, so from the couple responses, guess I will keep the battery up front
« Reply #6 on: May 23, 2011 - 11:30:53 AM »
I use welding cable , I run the power to the starter terminal , & a ground up to the tranny for max efficiency . You will need to add a 10 ga wire from the positive on the starter to the start realy on the inner fender to make this work
