Author Topic: Handling worse after Hotchkis install with 1.03" bars  (Read 2009 times)
Offline boydsdodge
  • Top end's unlimited....Aaaauuuuugghhhhh!!!!!!!!!!!
    • Boydsdodge
Re: Handling worse after Hotchkis install with 1.03" bars
« Reply #15 on: May 20, 2011 - 07:51:07 PM »
Am I missing something? I don't see anything that has anything to do with Hotchkis.
Please fill me in on what I am not seeing or reading.
Jackson from Toronto.
Offline Strawdawg
    • Vortex Buicks
« Reply #16 on: May 20, 2011 - 08:46:40 PM »
You have to read and look at the pics...pointing out that you can spend a lot of money on parts, but, if the foundation is no good, you can actually end up with something worse than you started out with.  Let's see if I can simplify this down.  Hang a stiff suspension set up on a weak frame and the forces end up moving the frame around more than it did before and the end result was worse handling.
Sorry to confuse you
