Author Topic: Pittman arm question  (Read 1203 times)
Offline Barracudadan
« on: May 17, 2011 - 12:08:26 AM »
I need a new pitman arm for my 72 Barracuda. Rockauto lists this one. MOOG K7076  Pitman Arm $56.79 it`s listed for 73-74 cuda/challengers. Will this work on a 72? I don`t see why it wouldnt just want to make sure.
Offline footin70rt
Re: Pittman arm question
« Reply #1 on: May 17, 2011 - 12:45:48 AM »
I believe there was a design change for starting in '73. And if I remember right the change is a slight angle difference to the arm if you compare it to the older one.  Wish I could remember how much different, but it was noticeable when they were side by side.
Thomas
Driving the same 70 R/T since October 1985
Native of Bozeman, MT
Offline UKcuda
  • Tell them I'm on my way
« Reply #2 on: May 17, 2011 - 03:55:00 AM »
Actually, I think the design change in '73 was in the size of the steering box output shaft - '73 and later pitman arms have a larger hole for the shaft.
'72 'cuda
Offline Katfish
  • 70 Challenger
« Reply #3 on: May 17, 2011 - 06:55:04 AM »
[/quote
 :iagree:  The older (smaller diameter hole) parts are 3x the cost.  If you're thinking of switching steering boxes for a Firm Feel or similiar unit, now's the time to get the larger diameter unit.
Offline UKcuda
« Reply #4 on: May 17, 2011 - 08:29:41 AM »
But I have seen somewhere that the later boxes wear out much faster.  Something to do with not having the same sector adjustment I think I read  :dunno:
'72 'cuda
« Reply #5 on: May 17, 2011 - 08:36:25 AM »
 :iagree: X3  bigger  shaft
« Reply #6 on: May 17, 2011 - 08:40:10 AM »
Thanks for the info guys you saved me the time and agravation of ordering the wrong part. My steering box seems ok so I hate to change it out just for this. PST sells the pitman arm I need for around $110 so thats not too bad.
