Author Topic: Questions with Regard to the Shaker Hood - Attaching Feet & Grouding Straps.  (Read 3829 times)
Offline 72ls5fla
Hello ----
On a SixPack car, were the attaching feet installed from the factory?
Also - does anyone have a picture or two of the grounding straps installed?  I looked all over the assembly and can't find any.
Last thing I need is for the thing to build up a static charge.
Thank you in advance....
Bill
Offline cudaized
    • Ola's `cuda page
1970 `cuda340 convertible 4-speed Rallye Red with Red interior
www.cudaized.com
1970-71 Plymouth and Dodge E-Body Convertible Registry
www.ebodyconvertibleregistry.com
Offline 72ls5fla
thanks for the pics....    :thumbsup:
Offline 72ls5fla
I ordered  the grounding straps - should have them next week.
Can anyone tell me if the 440 sixpack with the shaker would have come from the factory with the feet/supports?
If so, where do they hook up?
If anyone has a picture or two ot would be SO helpful.
The bubble bounces around some, even with the aircleaner wing-nuts tightened up pretty tight.
Offline mopardave
  • Sponsor
    • rosevillemoparts
yes, 340 and 440 had them.
they were rubber coated L brackets that  rest on top the valve covers,
http://www.rosevillemoparts.com/product_info.php/p/feet-6-pack-support-base-plate-340-and-440/products_id/6127
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline 72ls5fla
where and how do they attach to the base plate?
I am guessing that the feet are not spot welded to the valve cover - is that correct>  They just snuggly rest on it.
If you have a pciture that would be awsome.
BTW --  thanks for the link.
Offline ksierens
    • 70 Challenger Resurrection
There is a bracket welded to the base plate that the "L" shaped foot bolts to.  The rubber coated foot just rests on top of the valve cover.
See the view in circle "W" below.
Kurt - SE Michigan
Offline 72ls5fla
thank you so much!!!
I guess that the best way to proceed is to find where the feet would natuarally fit (up front) under the base plate, mark and weld the angled attaching brackes in.
I will order the kit from Roseville Monday.
This is a great forum - and thanks to all who helped!
Bill
Offline ksierens
I measured mine for you.  It looks to be about 6 3/8" towards the front from the center stud on the drivers side, and about 6" on the passenger side.
Kurt - SE Michigan
