Author Topic: Best spotweld cutter?  (Read 3615 times)
Offline lemming303
  • San Antonio, TX
« on: May 21, 2011 - 08:02:20 PM »
I need a better spotweld cutter. I have the cheap Napa one. It's alright, but it tends to jump around alot, even when using a marking punch. I have been looking at both the Eastwood "no walk" or whatever it's called, the one that has the small bit in the middle to make a "pilot hole" so it can't walk around, and the cobalt ones that have a point in the middle to cut first and then the bit cuts the spot weld instead of the outside ring like the eastwood. Which should I get? Thanks for the input.
Kevin
73 Challenger Rallye - first project
Offline rallye73
  • Model cars for the big boys!!
Re: Best spotweld cutter?
« Reply #1 on: May 21, 2011 - 09:26:06 PM »
Blair makes really good spot weld cutters also.
John Moorman
1971 Challenger R/T 383 4 speed (waiting it's turn)
1973 Challenger Rallye 340 4 speed (undergoing full resto)
2003 Dodge SRT-4 Stage 3 turbo daily driver-been as fast as 11.97et
1995 Dodge Neon Sport Coupe DOHC 5 speed Nitro-yellow-green (one of 527 built)
Offline berna4406
  • Sinister
« Reply #2 on: May 22, 2011 - 01:34:02 PM »
I prefer a spotle,they are great for drilling out spot welds.They are pricey but worth the money. Spotle TH-902  www.spotle.nl    they do have suppliers here in the US
                                                         Good Luck Sam
Offline elitecustombody
  • Supra collector
« Reply #3 on: May 23, 2011 - 11:14:56 PM »
Buy Blair and be done with it. I have tried and used just about every spotweld cutter,nothing cuts faster  and lasts longer
Stefan B
Offline lemming303
  • San Antonio, TX
« Reply #4 on: May 24, 2011 - 08:01:05 AM »
Thanks wages. I appreciate it.
Kevin
Offline Brusco
  • GO GO GOLDFISH !
« Reply #5 on: May 24, 2011 - 08:12:00 AM »
I used Eastwood cutters to remove the entire front clip of the"GOLDFISH" and only went through two of them,I drilled a very small pilot hole and it was no trouble at all.Only took me an hour at the most and it came out clean,Brusco
Oooooh Barra-Barra-CUDA !
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #6 on: May 24, 2011 - 08:32:18 AM »
NOw it requires paying a lot more attention, but I have found that using an air hammer work the best at breaking spot welds. I had to remove both inner fenders on my 70 Challenger, after an hour of fighting with drilling out spot welds on one and still not done I switched to the air hammer and finished it in like five minutes, then got the other one out in like 15 minutes.
But like I said you really have to be careful or you will damage the metal you don't want to replace.
1996 Dodge Viper GTS Coupe
Offline lemming303
  • San Antonio, TX
« Reply #7 on: May 24, 2011 - 09:48:02 PM »
I've been using the hammer too, but I tend to get sideways sometimes so I really like the cutter. I have actually been looking at this carbide cutter. It's made for cutting new car steel, so I would imagine it would cut through the old stuff like butter.....It's really expensive though so I don't think I would be getting one of these for a while, just a possible future investment.....
http://www.autobodydrill.com/products/Carbide-Boron-Spot-Weld-Cutter.html
Kevin
