Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
Rally gauge conversion from standard gauge set up?
« previous
next »
Print
Pages: [
1
Author
Topic: Rally gauge conversion from standard gauge set up? (Read 837 times)
orcubsfan
Jr. Member
on:
May 23, 2011 - 02:54:50 PM »
Hi all, does anyone know if a conversion from a standard gauge set-up to rally gauges is do-able?
Has anyone done it, seen it done?
Not a fan of the tach mounted on a steering column.
Thanks,
Bill
Logged
MEK-Dangerfield
C-C.com Expert
I don't get NO respect! Member since 1/25/2002
Re: Rally gauge conversion from standard gauge set up?
Reply #1 on:
May 23, 2011 - 03:46:49 PM »
It's a common swap. You'll need to find a constant power source for the clock, and a switched power source for the tach. You will also need to replace the oil pressure sending unit. The one for the dash warning light won't work on a Rally set up. The light bar is also different for the Rally gauges(4 bulbs vs. 3 with the standard set up). This might or might not matter to you.
Logged
2016 SXT+. 1 of 524 SXT+'s in Plumb-crazy for 2016.
rusty dodge
Jr. Member
74 challenger 440-727-3:55
Reply #2 on:
May 26, 2011 - 01:40:51 PM »
I have done it, and may I add that the heater control panel is also different. You also need to run a wire out to the coil for the tach signal.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
