Shifter Cable
Author Topic: Shifter Cable  (Read 5438 times)
Offline DodgeFreak
  • Cars and trucks are my friends..
Re: Shifter Cable
« Reply #15 on: December 21, 2004 - 08:48:59 PM »
 :eekbig: :eekbig: :eekbig: :eekbig:  threw it out???  Who throws out parts??
i know a guy that threw out a 340 and it got crushed..it was a 70 too...............and he threw out some good heads and a whole bunch of mopar stuff becasue he didn't have a use for it...
74 Plymouth Duster- restoring
77 Dodge D150 shortbox- as long as i don't change my mind will be a step side dually diesel or a 383 powered truck
04 durango 4.7
Offline Carlwalski
Re: Shifter Cable
« Reply #16 on: December 21, 2004 - 10:29:19 PM »
That sucks!!!!!!! 340's Are getting pretty darn hard to find these days.  :ack: :'(
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
nivvy
Re: Shifter Cable
« Reply #17 on: December 21, 2004 - 10:52:37 PM »
Fixed the problem.............Didnt have the right ratio swing arm lever on the tranny that the shifter cable attached to under the car....switched it with one of the others that came with kit and it works perfect now! :burnout:
8 Pack
Offline Carlwalski
Re: Shifter Cable
« Reply #18 on: December 21, 2004 - 11:47:47 PM »
Glad to hear you fixed the problem 8 Pack.
What have you done to your TF-727?  :dontknow: Is it fully race set up or a bit-of-both?  :thumbs:
nivvy
Re: Shifter Cable
« Reply #19 on: December 22, 2004 - 03:14:07 PM »
Coan 3000 stall converter with cheetah forward manual valve body/ ray bestos bands and clutches.......almost ready to fire the car up...
8 Pack
Offline DodgeFreak
Re: Shifter Cable
« Reply #20 on: December 22, 2004 - 10:08:57 PM »
OOOOOOOOOHhhhhh..........Glad you figured it out......but i do remember now that i had to drill my stock swing arm lever tog et it towork....sorry i wish i could of remembered it to tell you...
04 durango 4.7
Offline Carlwalski
Re: Shifter Cable
« Reply #21 on: December 22, 2004 - 10:10:33 PM »
8 Pack
Keuwl!!!  :D Sounds like it's had a little work done.  :grinyes:
