hey all ....
Well I got the car under control ....
Here are the things I had to correct to stop the over heating.
1. I had a 3 row core with 5/8" tubes on 1/2" centers built for the radiator tanks/brackets. It was also increased to 2.5" wide.
2. Set the initial timing to 5 degrees advanced. I also backed the screw in the vac. adv. can ccl 1.5 turns.
3. Turned out that the center carb had 59 jets and an odd power valve, so I put 64 jets and a 6.4 PV. Did a complete rebuilt/clean on all three carbs.
4. purchased a high flow water pump from SUMMIT.
I can now drive the car all day long in 95-99 degree weather and in town or HWY, it runs around 180-195.....
Plus as an added bonus - after messing with the jets,PV and timing - I can run pump gas and no pinging under any load.
The surging I would feel around 2500-3200 RPM also went away - now the car is smooth at any RPM.
The new water pump and thicker core moved the fan 3/8" closer to the radiator.
Want to thank everyone for all the great ideas and suggestions!!!!!!!
Bill
