Author Topic: six pack throttle return springs  (Read 476 times)
Offline Jymy
    • 3470 Six Pack
« on: May 26, 2011 - 11:11:05 AM »
Hi,
should there be two  throttle return springs in 340 six pack carbs set up? I noticed from  the service manual that there is also mentioned "assistant spring"? Should it work only with the main spring? My throttle return is now quite slow and ordered the original spring because it did not seemed to be correct but then noticed this assistant spring.
Thanks!
...and there goes the Challenger, the last american hero, the soul hero, the demigod, the super driver of the golden west. The last beautiful free soul on this planet!
Re: six pack throttle return springs
« Reply #1 on: May 28, 2011 - 10:22:21 AM »
to my knowledge there was only one spring but I would never run with less than 2 as I have seen what happens when one spring breaks . there is a spring on the throttle shaft of the carb to assist closing
