Author Topic: oil gauge  (Read 832 times)
Offline HemiOrange70
oil gauge
« on: May 26, 2011 - 12:33:08 PM »
I need  12v wire to power a redline repo oil gauge. If I use the stereo wire will it not blow the fuse?
Re: oil gauge
« Reply #1 on: May 26, 2011 - 03:51:00 PM »
It's not likely to blow the fuse. Especially if you have an after market radio that draws far less current than the originals. I would sure give it a shot.   :grinyes:
Offline Grec
Re: oil gauge
« Reply #2 on: May 31, 2011 - 03:27:59 PM »
Not sure if this is applicable to you, but on my 73, there were two empty 12v slots on the fuse box. One constant on and one for ACC. Obviously you'd want the ACC one. That's a nice clean place to safely wire something in if it hasn't already been used.
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Re: oil gauge
« Reply #3 on: May 31, 2011 - 10:36:42 PM »
Am I missing something?...Would a reproduction gauge not need to be powered through the voltage limiter?
Offline Grec
Re: oil gauge
« Reply #4 on: June 03, 2011 - 07:56:22 PM »
I would assume no. They're prob meant to run on 12v while the originals use little coiled strips of metal that open up and move the needle with current. That's why they have to be stepped down.
That's my understanding, at least. :-)
- 440 Six Pack
Offline UKcuda
  • Tell them I'm on my way
Re: oil gauge
« Reply #5 on: June 05, 2011 - 07:47:06 PM »
I think Bullitt's point is that it's only a repro. if it hooks in like the original.  Otherwise it's not a repro. it's a replacement or an alternative.
'72 'cuda
Re: oil gauge
« Reply #6 on: June 05, 2011 - 07:54:28 PM »
That's what I was thinking, a reproduction might need the lowered voltage but I see that what Redline makes to fit the standard dash has the internals of a new gauge which would not.
