I have been working on the car... honest!
Just heaps of stuff that isn't worth taking photos of.
Stripping things, mocking up, planning, etc...
I decided towards the end of last year that I was going to go a bit further (again ha ha) than I was planning, and replace the roof, quarters, and dutchman panel on the shell.
And step things up a few more notches with regards to custom work and some performance stuff like brakes and steering.
So it's been fairly slow progress, with plenty of time off to do some of my other projects.
Here's some work from the weekend:
Added the braces that tie the rollbar into the c-pillar sail-panel area. These bolt on via the upper seat belt mount and an additional 10mm bolt.
Here's the plate welded to the sail panel to reinforce the area. There's a 10mm nut welded to the back for the additional bolt.
The plates on the rollbar are fixed with a bunch of heavy MIG tacks for now. I'll grind these back and TIG the plates on just before the car is done, in case any thing needs to change.
I also added a couple of gusseting braces to the firewall to inner-fender-brace area.
I wasn't satisfied with the way the stiff inner fender brace butted into the weaker cowl area. So these plates will help spread the load.
