Author Topic: Kuda progress  (Read 132368 times)
Offline wally426ci
    • maryland mopars
Re: Kuda progress
« Reply #195 on: August 30, 2012 - 07:03:15 AM »
Holley came out with those Black carbs just in time!  :2thumbs:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Re: Kuda progress
« Reply #196 on: August 30, 2012 - 11:06:28 PM »
They've been out for a year or more.
Offline wally426ci
    • maryland mopars
Re: Kuda progress
« Reply #197 on: August 31, 2012 - 06:55:48 AM »
I guess I just started seeing the adverts in Hot Rod in the past few months so I figured they were newer.....  :chatting:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline Raw Untamed
Re: Kuda progress
« Reply #198 on: September 01, 2012 - 01:24:01 AM »
oh oh!
Hey Beck,
This build is spectacular and you've been doing excellent work.  Very inspiring.
Would you post some more pics of the outer wheelhouse mod, and fill us in about exactly how you did it?
Thanks,
Joey
Joey
71 Challenger
Offline 'Cuda Hunter
  • Tastes Like Chicken
Re: Kuda progress
« Reply #199 on: September 01, 2012 - 11:45:08 PM »
 :popcorn: :popcorn:
Offline Challenger6pak
Re: Kuda progress
« Reply #200 on: September 09, 2012 - 04:38:32 PM »
I'd also like to see more pics of the wheel house mod.
Offline Beck
    • BECK KUSTOMS
Re: Kuda progress
« Reply #201 on: September 09, 2012 - 11:42:43 PM »
Hey guys,
I did the outer wheel house mod before I cut the quarters off, back when I wasn't planning on taking the car project as far as I am now.
The car was on the rotisserie, and I just cut a hemispherical section out, leaving an edge to weld to all the way around.
I made cardboard templates for the two pieces on each side that replaced the old stamped section, then replicated them in sheet metal.
I tacked the two bits together and to the car, then cut the tack welds that attached the joined pieces to the wheelhouse.
Welded the two bits together fully, cleaned up the weld, then welded them into the car.
My car used to rub the rear tires in that spot, and there is plenty of room now.
Cheers!
Offline Raw Untamed
Re: Kuda progress
« Reply #202 on: September 10, 2012 - 06:56:37 PM »
Beck, thanks so much for the extra info!  I want to do this to my Challenger.
Joey
71 Challenger
Re: Kuda progress
« Reply #203 on: September 10, 2012 - 11:19:15 PM »
 :iagree: Thank you.
Offline js23nob
Re: Kuda progress
« Reply #204 on: September 11, 2012 - 05:35:36 AM »
i copied the rear wheel well mod as well
Mopar or no car
Offline Beck
    • BECK KUSTOMS
Re: Kuda progress
« Reply #205 on: October 20, 2012 - 02:14:19 AM »
Some of the latest work:
Test fit the motor and drivetrain to weld in guides for the header flanges, so I can fab the exhaust with the body on the rotisserie.
I raised the angle of the drivetrain a bit more than this photo, to get some extra ground clearance.
3.5" 304 stainless, for the dump pipes straight back from the 3.5" header collectors.
X-pipe work.
It's going well, but damn it's slow sometimes when you've never done this stuff before!
Offline GranCuda1970
Re: Kuda progress
« Reply #206 on: October 20, 2012 - 02:21:51 AM »
 :2thumbs: F#$% 'N Aye that is gonna be bad arsed!  :bigsmile:
Offline dutch
Re: Kuda progress
« Reply #207 on: October 20, 2012 - 02:27:46 AM »
all good things take a bunch of time.  Man,  just look at you.... it`s not that long ago you first started experimenting with fab/ welding.... top notch...I`m impressed  :worshippy
*** Bart ***
Re: Kuda progress
« Reply #208 on: October 20, 2012 - 07:32:58 AM »
Looking good Aaron! :2thumbs:   Are you going to use electric dumps?
Offline Beck
    • BECK KUSTOMS
Re: Kuda progress
« Reply #209 on: October 21, 2012 - 06:44:46 PM »
Cheers guys!
Brad, I do plan on electric cutouts and side exit pipes eventually, but initially I'll be using removable bolt on caps.
I'll be making two sets of caps, one set with an internal guide to flow the exhaust gas smoothly into the 3" x-pipe.
Then I can test the two, to see the effect the normal caps have on performance.
I'm guessing there will be an increase in back pressure and a drop in flow when the plain caps are on, due to the turbulent flow
caused by the dump pipe design.
In case anyone is wondering, I've designed the dump pipes to effectively be like open headers.
Nothing sounds like open headers, and normal dump pipes with a Y design don't have the same noise and presence.
