Author Topic: 440 0il pan Mods  (Read 1485 times)
Offline punisher72
  • 70Challenger 440 4 speed yeeehaaaaa!!!!!!!
440 0il pan Mods
« on: May 28, 2011 - 05:02:43 PM »
Im tossing up whether to buy a new oil pan or just modify my standard one by adding wings.
I have a standard stroke milodon windage tray i want to use,so may as well change both at once.
I like the ground clearance i have now. By going to a larger sump i lose about 2" of clearance.
Or if i bought a hemi sump,it has a baffle and still a lot of ground clearance.
I want to do some drag racing as soon as i have some teething problems out of the way,this is why im looking at the oil pans.
What are your thoughts?
Anyone got pics of their modified oil pan?
 :cheers:
« Last Edit: May 28, 2011 - 05:25:20 PM by punisher72 »
Re: 440 0il pan Mods
« Reply #1 on: May 30, 2011 - 10:00:08 AM »
I welded boxes on the sides of my oil pan instead of deepening it, I ended up with 11 qt capacity !! The Milodon road race pan is similer but I think it needs to be installed once the engine is in place in the car
Offline punisher72
« Reply #2 on: June 03, 2011 - 11:48:27 PM »
Wow :eek2: Thats a lot of oil CP!!!!! I was looking for another litre or so.....
Im thinking i might just track down a 2nd hand hemi sump.....
I wont rev over 6000rpm.
Would i be alright to use the standard milodon windage tray with the hemi sump?
Not too much baffleing?
« Reply #3 on: June 04, 2011 - 09:05:03 AM »
the plates inside the hemi pan stop sloshing so the oil will stay in the sump , the windage tray separates the the turbulance from the crank from the sump so it doesn't tend to lift the oil in the sump , they are designed to work together , if you want to be more effective use a crank scraper as well to cut the excess oil off the crank .
 with my modified pan I was shifting at 7200 rpm with the front wheels well of the ground leaving the starting line & never had a brg problem in 9 years . All I did was add a box to each side of the sump & figured I would gain 2-3 qt capacity , I also added a plate at the rear of the sump angled slightly downward to keep the oil in the sump , I kept the stock ground clearance but misjudged the anticipated 7-8 qt capacity by 3 qts !!
Offline punisher72
« Reply #4 on: June 04, 2011 - 10:08:39 PM »
Ok. I've decided to just add to my standard sump. I will keep the same depth so I keep my pickup and will add wings and put a plate at the back to stop the oil sloshing back.
Thanks for your help CP once again  :2thumbs:
Offline punisher72
« Reply #5 on: June 05, 2011 - 04:16:43 AM »
I started on my pan today. I mocked up the wings roughly. They are all tacked together and then i trial fitted it to the motor.
1/4" clearance on driver side and 1/2" on pass side.
Not sure how much oil it will add? Wont know till i fill it up  :thumbsup:
Im guessing around 1 to 1.5 litres.....     1 litre is 1.05 quarts in yankee language  :cheers:
Offline Todd Smith
« Reply #6 on: June 06, 2011 - 05:20:31 PM »
Chryco, Have a pic of that one? I'm not spending $445.00 for a Milodon pan.  :22yikes:  11 qts is a little over the top, but only a little. I like lots of oil available to my motor.
My 3500 diesel 1 ton takes 10 qts.
I don't suffer from insanity.
I enjoy every minute of it!
Offline punisher72
« Reply #7 on: June 07, 2011 - 07:26:59 AM »
Heres the finished product!! I will fit it tomoz and see how much oil it takes now  :bigsmile:
« Reply #8 on: June 07, 2011 - 10:18:17 AM »
Punisher, you might want to add some baffels in there as well to help keep oil from climbing the walls during acelleration, braking, and cornering.
There is more to a good oil pan than just capacity. Like CP said, there are different pieces that serve different roles in controlling the dynamics of the oil in motion.
Offline punisher72
« Reply #9 on: June 07, 2011 - 06:11:50 PM »
How do i do that HP2? CP did say to put a plate to the rear of the sump? Would this be a 1" strip down near where the pickup is all the way across?
« Reply #10 on: June 08, 2011 - 10:55:45 AM »
I'd put a 1 to 1.5" shelf just down past the radius that goes to the sump, around all four sides if this is a street car.  A windage tray is also a good addition. It is worth a 5 horsepower gain as low as 3500 rpm and more as the revs increase.
Offline punisher72
« Reply #11 on: June 09, 2011 - 06:36:38 AM »
Cheers HP2. I added a piece to the back only as i want to go fast in straight lines only.  :burnout:
I also fitted a milodon windage tray.
Havent filled with oil yet,just finished fitting it all back together tonight.
Offline Todd Smith
« Reply #12 on: June 09, 2011 - 01:31:19 PM »
Sweet   :2thumbs:
