Author Topic: Edelbrock TM5  (Read 4863 times)
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
Edelbrock TM5
« on: December 21, 2004 - 03:36:48 AM »
Does anyone here have any experience with running a Edelbrock TM 5 intake manifold? I have a quick chance of picking up a NOS unit for $100. I ran a TORKER for a while but didn't like having to twist my motor so hard to make HP with it(power band was like 3500 - 8000). Right now I'm running a highly modified Edelbrock LD340 (also known as LD4).TM5 power band is like 2500-6500 which is perfect if true.
Re: Edelbrock TM5
« Reply #1 on: December 21, 2004 - 10:43:16 AM »
sorry I have never used the TM5
Offline OUTLAW
Re: Edelbrock TM5
« Reply #2 on: December 21, 2004 - 03:12:54 PM »
well I haven't either but if the specs are close to correct then its worth a try ....plus for$100 for NOS manifold I can't go wrong ...someone will need it somewhere if I dont like it ....LOL
Re: Edelbrock TM5
« Reply #3 on: December 22, 2004 - 01:17:13 AM »
True
kudakidd
Re: Edelbrock TM5
« Reply #4 on: December 22, 2004 - 01:26:36 PM »
Outlaw, the TM-5 is the brother to the TM-7, which was originally called the Tarantula series. It's still a good manifold but is more suited to the track as it's powerband is up there. You're better off with the Performer RPM series for dual useage. KK
Offline OUTLAW
Re: Edelbrock TM5
« Reply #5 on: December 22, 2004 - 02:10:50 PM »
according to edelbrock the power band is 2500 to 6500 which is more suited for hot street usage. But you are correct it is a Tarantula manifoldand more street worthy than a torker. the performer rpm is a dual plane manifold which is what I am trying to avoid using
« Last Edit: December 22, 2004 - 02:12:42 PM by OUTLAW »
Offline mrbill426
    • All Around Mopars
Re: Edelbrock TM5
« Reply #6 on: May 12, 2006 - 07:15:17 PM »
Sooo, how did the TM-5 work out??
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
