Author Topic: What media to use for blasting?  (Read 3181 times)
Offline lemming303
  • San Antonio, TX
« on: May 30, 2011 - 09:18:12 AM »
I finally came to the decision to blast my car myself as I will save a good chunk of money doing it and also I can build a frame support in my shop, leave the car on there and remove as much metal as possible for blasting without worrying about any twisting or warping during shipping. Anyway, what media should I be using to blast with? Thanks for the help.
Kevin
73 Challenger Rallye - first project
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: What media to use for blasting?
« Reply #1 on: June 03, 2011 - 10:10:48 PM »
most of the shops around me use a mixture of different types media, if you know of a shop ask them and see where they buy it. NO silica sand, that builds to much heat for body panels. frames are fine with it, i googled this, see if it helps
http://www.kramerindustriesonline.com/blasting-media.htm
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
« Reply #2 on: June 04, 2011 - 10:57:04 AM »
How rusty is the outer body sheetmetal? Underneath?
When I media blasted my car, I just did the underside and engine compartment using Aluminum Oxide.
A faster cutting abrasive means less blasting time per square foot.
Strip paint off first with paint stripper. This will leave you less time spent trying to cut thru 2 or 3 layers; lower psi will be required also reducing risk of any warping.
I stripped the outside by hand and sanded 120 grit. That is really the lowest risk way to go.
Offline lemming303
  • San Antonio, TX
« Reply #3 on: June 04, 2011 - 07:54:17 PM »
Mike, there's quite a bit of rust. As far as the outside sheet metal goes, most of it is going to be replaced. I'm just worried about cleaning the support structures and door jambs and things like that.
Kevin
« Reply #4 on: June 04, 2011 - 08:41:56 PM »
If you do plan on doing a major amount of blasting on the car, once you're done, get a strong lawn/leaf blower to get the media out of hidden places. Then after follow it with a high psi air hose extension blow tip. HF sells them.
Offline jforest1
« Reply #5 on: June 04, 2011 - 10:00:08 PM »
Read this before selecting:
http://www.osha.gov/dsg/etools/silica/protect_against/stopsandblasters/stopsandblasters.html
The table is useful as well.
So main thing is choose a low/no silica media, and get a good gas mask.  You don't want to be breathing in glass particles to begin with, certainly not with silica in it.
JF
'73 Cuda 340 Slapstick, A727 Torqueflite Transmission, Edelbrock Thunder Series AVS 1806, Vintage Air Gen IV A/C system
« Reply #6 on: June 04, 2011 - 10:20:31 PM »
All the media is bad to breathe in no matter what type.
 And don't forget your eyes either.
It can get hard to see thru the plastic lens.
Get some plastic polish if you plan to re use your goggles for a while. Or peel offs.
Offline lemming303
  • San Antonio, TX
« Reply #7 on: June 05, 2011 - 01:24:44 AM »
I have a 3M painters mask that should be good. I also have my wily x goggles from the marine corps, I would think they'd work too. Thanks for the help yall
Kevin
« Reply #8 on: June 05, 2011 - 01:48:11 AM »
The painters mask isn't enough. You'll need to cover your head like an Arab in a desert sand storm.
Get some coveralls and heavy leather gloves. This stuff can hurt when it hits skin.
Offline lemming303
  • San Antonio, TX
« Reply #9 on: June 06, 2011 - 01:08:42 AM »
Oh ok. Thanks for the advice.
Kevin
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #10 on: June 06, 2011 - 09:39:15 AM »
I just purchased a storage unit that the fella who owned it had a ton of medical records.
It appears that he had to have major surgery because the sand blaster he was using got out of control and hit his leg.
He had to have major surgery as he has opened up a hole in his leg that was about 6" long and about 2" wide.
He had also impregnated his leg with the media he was using.  I don't think it was sand.
Watch your ars when you are doing it because those things really can hurt you.
Offline the_engineers
« Reply #11 on: June 06, 2011 - 11:50:52 AM »
Talk to some of the industry around you. HAZMAT Level 2 and 3 suits are enclosed and they expire. Someone that has an expired suit may be willing to give/sell the suit if you are willing to sign a waiver that it will not be used with any chemicals.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
« Reply #12 on: June 06, 2011 - 12:12:04 PM »
My mask came with the HF pressure pot.
Don't forget the ear protection too.
Sand/media in the ears isn't good either as it sticks to your ear wax in your ear canals.
Offline lemming303
  • San Antonio, TX
« Reply #13 on: June 07, 2011 - 12:28:25 AM »
I have very thick cotton Fire Resistant coveralls for work, do you think they will work for a suit?
Kevin
« Reply #14 on: June 07, 2011 - 10:00:08 AM »
Should be OK
