Author Topic: Damn Hyundai Sonata A/C  (Read 16855 times)
Offline shadango
« on: May 31, 2011 - 07:00:51 PM »
So the A/C in the wife's Sonata (2006) quit.  Just a few days after we got her Mustang home and only 700 miles since the warranty ran out.
 :banghead:
Well, it is what it is.  LOL
Blower blows fine....temp adjuster goes from hot (in the red zone) to warm in the blue zone....so no cold air in other words.
So I have it diagnosed to the point where there is power going to the clutch power lead. No clutch action in AC or defroster mode.
Low side pressure is at 100lbs which is too high, but I was told that that is normal when the compressor is not running.
I dont have the gauge for the high side.
I am thinking that the clutch gave up the ghost.   Its in such a PITA spot, and I have no experience with A/C so likely taking it to a shop.....but just so I dont get screwed I would like to figure it out....
Anyone have A/C experience??
This one is gonna hurt money wise I am betting.
Offline Matt70
Re: Damn Hyundai Sonata A/C
« Reply #1 on: May 31, 2011 - 07:32:46 PM »
If you have power to the clutch and it's not kicking on sounds like it's bad. Try to tap the clutch with a screw driver, sometimes they are weak and with a tap it will kick in. They are easy to put on as long as you can get to it. If you have to pull the compressor the system will have to be drained, vacuumed and refilled. So you'll need the line set, a vacuum pump and the R134 of course. Good luck.  Matt
Oh and being that close to the warrenty going out I'd take it in and see if they will work with you.
« Last Edit: May 31, 2011 - 07:34:34 PM by Matt70 »
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf.
George Orwell
Offline 06Daytona
« Reply #2 on: May 31, 2011 - 07:48:05 PM »
Don't know if this helps, but my wife's new 2006 Honda Civic had the same symptoms. We took it in to get it checked out and we were told it needed a new condenser.
I agree about seeing if they'll work with you since it's so close to the end of the warranty.
1972 Cuda 340 4 barrel 4 speed that looks like a 71
2006 Dodge Charger R/T Daytona
2005 Dodge Ram 2500 Diesel 4X4
2006 Chrysler PT Cruiser Convertible (Kidmobile)
1972 Dodge Charger 318 auto
1970 Challenger 440/727 auto
1973 Plymouth Duster 340/auto (Making it Panther Pink for the wife)
2006 Honda Civic Hybrid (It doesn't save gas, it just diverts it to the Cuda/Challenger)
In desperate need of more property for my growing Mopar family
Offline Cooter
    • christinecarclub.com
« Reply #3 on: May 31, 2011 - 07:53:42 PM »
There is an A/C Clutch Relay under the hood in one of those relay boxes on the fenderwell IIRC...Tap on it and see if it comes on...If not......
There's a pressure switch you can "Jump" to force the compressor to run...Careful though, as there will be NO CYCLING OF COMPRESSOR while you have the pressure switch "Jumped"...So only do this to varify that the compressor clutch is working...I got a feeling it is just low enough to where it won't cut the compressor on....100 LBs on the low side not running only tells you there's "Something" in the system..May not be enough...You will need to get a service manual to find the pressure switch, but it is usually located in one of the lines...If the pressure switch has THREE (3) or more wires, DO NOT JUMP IT as you won't know which wires go straight to the compressor and which go back to that auto climate Bullsh*t...
If this works and you save the diagnosis charge at a shop, Please PayPal my account the Diagnosis charge thank you... :grinyes:
« Last Edit: May 31, 2011 - 07:57:53 PM by Cooter »
Offline shadango
« Reply #4 on: June 04, 2011 - 08:58:24 AM »
hey there
well i found that there is power getting to the compressor, so that should rule out switches etc shouldnt it?
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
« Reply #5 on: June 04, 2011 - 09:23:42 AM »
hey there
Can you hear any sounds from the clutch at all? If not then I think it seems like the clutch has gone bad.
Worlds first e-body trailer.    Severna Park, Maryland
Offline hpe600rt
  • how sweet it is
« Reply #6 on: June 04, 2011 - 06:59:38 PM »
that just sucks
Offline Matt70
« Reply #7 on: June 05, 2011 - 02:27:12 PM »
hey there
Yes if you are getting power to the compressor that would rule out the switch
George Orwell
Offline the_engineers
« Reply #8 on: January 17, 2012 - 01:11:25 PM »
Many people love the Sonata. It is a fantastic, family-friendly sedan that could be driving each day. It has a sporty look, comes with a ton of extra benefits, and is inexpensive. Most dealers will recommend it to you if you ask for the best recommendation for a family car. The car dealerships in Houston are especially helpful in helping you get everything you need in an automobile. To find a car dealership in Houston that can help you, look into Hyundai Sonata dealership Houston.
It's like it's related, but not. Thank goodness for spam!
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline moparclown
« Reply #9 on: January 17, 2012 - 01:37:46 PM »
HA HA HA HA HA,my wifes 2001 Hyundai XG300 just got back from a dealer where they had to replace the front frame.Its a total POS!Then they handed her an estimate for work needed ---$3300 worth and the car only has 72000 miles on it.My opinion is they should all get loaded back up and sent back to where they came from.Oh why did I trade my Caddy in on it.
Offline Matt70
« Reply #10 on: January 17, 2012 - 07:54:42 PM »
Well now that we got some A hole's spam post and this thread is back..... Shadango what happened did you get it fixed?
George Orwell
Offline shadango
« Reply #11 on: January 20, 2012 - 06:01:35 PM »
Yep...turns out it was a bad clutch...had the dealer replace it and it was actually relatively cheap.....like $270 as I recall....the part is $150 or so.....but getting to it is a PITA.
Worth every cent.
Fast forward to the last month or so, now having problems with the A/C in my Durango, and my motorcycle's engine died.....when it rains it pours......but one great thing -- brought a new bike home last evening.  :)
